M=tuned Turbo kit : little update for now
Old 07-13-2009, 02:40 AM
  #621
weezyfbayba's Avatar
ill just not put anything on there till i can get a catch can
weezyfbayba is offline
Old 07-13-2009, 02:41 AM
  #622
crush02342002's Avatar
well you want to put something on there for the time being...like i said it works its just not the ideal thing to do.
crush02342002 is offline
Old 07-13-2009, 02:58 AM
  #623
rangerryda's Avatar
On my kit, I had to tap the head in pretty far with a T-27 or T-25 thread tap and die set. I had to go in about 1/4 inch further for the T fitting supplied in my kit to actually thread. Before it was doing just like you said before and trying to thread half cocked. After I tapped it in (using loads of grease to keep the shavings) it went in like a beauty. My hose gets re-routed back into the intake pipe. I regularly check it to see if any oil is getting recirculated but the hose never has any oil in it. No residue. I pulled the valve cover off the other day and it has several baffles in my 07 to keep oil from making it through the other side so maybe the 05-06's don't? Not sure but at 9 psi on my ball-bearing T3/T4 T-Netics setup, no oil blow through yet!
rangerryda is offline
Old 07-13-2009, 03:04 AM
  #624
even with a catch can (pos catch can btw) i had oil make its way to the intake pipe...most likely it was due to high revs but not 100% sure. point of the filter on it is just to keep anything from going into the engine and to help keep oil vapor from possibly being sprayed in your engine bay.
Old 07-13-2009, 03:05 AM
  #625
good info though ranger...didnt think about using greas to keep the shards.
Old 07-13-2009, 03:08 AM
  #626
rangerryda's Avatar
Ya, i've seen some honda guys with those and they use them for like 30k miles soaked and their engine bays are filthy. If you replace them when they get damp, you'll be fine. Crush, does your valve cover have those baffles like mine? I'm not sure if they changed the design or if I'm just a lucky turbo'd TC.
Old 07-13-2009, 03:10 AM
  #627
iv never taken the valve cover off, i will soon though. got a head comeing this friday (stock used head) and may swap out heads for a bit and have mine pnp'd. just have to see how money flows plus i got to pay for turbo as well.
Old 07-13-2009, 03:11 AM
  #628
yea i jsut called my dude he is goin 2 pick up his tap& dye set from his friends and bring it to work tomorrow i may try it myself or let him do it.. ill hit this up with an update tomorrow after work !
Old 07-13-2009, 03:12 AM
  #629
im going to guess that mine is baffled as well since i had the filter for a few months and it never got wet but had a couple of oil spots on it.
Old 07-13-2009, 03:13 AM
  #630
sweet
Old 07-13-2009, 03:18 AM
  #631
rangerryda's Avatar
Just make sure to use TONS of grease when tapping and don't try to tap it in one shot. Tap 1/16 of an inch at a time. Basically, when the tap hits bottom, turn about 1/2-3/4 turn and back it back out. Clean out the hole, clean off the tap, and re-grease it. Rinse and repeat until your fitting goes in. Remember, TONS OF GREASE! lol
Old 07-13-2009, 03:21 AM
  #632
ecko04's Avatar
INSERT DIRTY JOKE HERE but it would be TOO EASY
ecko04 is offline
Old 07-13-2009, 03:22 AM
  #633
rangerryda's Avatar
I prefer anit-seize for stuff like that! lol Metallic secks ftmfw!
Old 07-13-2009, 03:24 AM
  #634
ok thats getting siged...lmao
Old 07-13-2009, 03:28 AM
  #635
ecko04's Avatar
DO EEET.....DO EEET NOW
ecko04 is offline
  #636
did it...lol
Old 07-13-2009, 03:38 AM
  #637
rangerryda's Avatar
I feel awesome that I could actually make a dirty joke without knowing it!! At least it was relevant! Now I can bask in my 15 mins of fame... lol. Ahem, so anyways, about that T-Fitting...
Old 07-13-2009, 03:40 AM
  #638
lmao
Old 07-13-2009, 03:47 AM
  #639
ecko04's Avatar
Nothing better than helping out a little while I wait for a certain someone ^ to lean out my tune in vac
BTW how was the slip-n-slide?
ecko04 is offline
Old 07-13-2009, 03:55 AM
  #640
my little girl is affraid of it unless im in it with here, then again i guess sliding into a sharks mouth would be a little scary to me too...lmao...btw its the 3d shark slip-n-slide (dont think its the slip and slide brand though, some other brand). she cant really slide down it unless i throw her butt down it (she tells me to do it...lmao). did you send me a log? i sent a fresh map that i did a little defueling in the vac areas (idle areas). how has the car been doing? still the same ish?
Quick Reply: M=tuned Turbo kit : little update for now
