M=tuned Turbo kit : little update for now
Old 07-15-2009, 05:20 PM
  #721
weezyfbayba's Avatar
ok the spring loaded bolts i had were bottumed out wasint tighting the 2 pipes together enough went and got some washers 1 side i got pretty tight went to tighted the other side and the bolt started stripping.. gotta go back to the parts store to get another spring loaded bolt......... ill update this once i get the new botl on and washers on
weezyfbayba is offline
Old 07-15-2009, 05:21 PM
  #722
also my wideband is about 4 inches away from me secondary o2 sensor so yea
Old 07-15-2009, 05:42 PM
  #723
ugh the brand new spring loaded bolts i just bought stripped man *** this pos bolts im just gonna use a regular bolt just wasited 6$
Old 07-15-2009, 05:43 PM
  #724
CarbonXe's Avatar
You have to use spring loaded bolts. Otherwise, it puts too much strain on the manifold and can cause it to crack. There was just a thread on that where a Dezod manifold cracked at the flange and it was because the downpipe was installed with standard bolts.
CarbonXe is offline
Old 07-15-2009, 06:11 PM
  #725
yea well the bolts i keep buying are pos so ive got 1 spring loaded bolt and 1 standard bolt for now ill order the spring loaded bolts from dezod tonight
so dounut gasket leak fixed for now
now the mani is still leaking sounds like a v8 truck
is that the reason why my afr's lean out so liek 17? then the line just comes up and stays on?
Old 07-15-2009, 06:14 PM
  #726
i can see that the bolts are all not even on the mani like tight that is i don't wanan crank them 2 hard and they snap that would blow...
also i can't find on dezod's site were the spring loaded bolts are.. and im gonna have to wait till friday to order the copper gasket from dezod
Old 07-15-2009, 06:26 PM
  #727
ok well ive narrowed down the exhaust leak to the right top side of the mani i tightend the bolts a little more the car runns kinda like crap tho
Old 07-15-2009, 06:44 PM
  #728
ok got the exhaust leaks gone it was running like shizzz because one of the injector rubber gromits fell off but thank god it was still laying back there hooked that back up.. idles so nice... ive just gotta find some good basemaps... my afr at idle is about 12.7
Old 07-15-2009, 08:57 PM
  #729
well there is absolutly no words to describe the ride i just went on im speechless 110% worth everything i went threw
Old 07-15-2009, 09:05 PM
  #730
crush02342002's Avatar
lmao....so hows the boost...lol
i wouldnt bother with the copper gasket, id go to a local toyota dealership and get a stock gasket...they run about 40 bux if you still need one...
btw youll have to give the car some time and miles before the idle afrs settle back down...however i do have a new map or two iv been playing around with. its ecko's tune iv been working on.
crush02342002 is offline
Old 07-15-2009, 09:08 PM
  #731
oh no the basemap im useing is so perfect at idle its between 14.5-15 and at a cruise its at the same but in boost its like 10.5-11 thats good right?
Old 07-15-2009, 09:11 PM
  #732
a guy on here gave it 2 me he has the same kit as me running the same psi as me 8 psi
Old 07-15-2009, 09:31 PM
  #733
I thought i had given it to you...lol....its ok for now to run rich but it can and will kill your 02sensor and leave some nasty diposits on your valves if ran for too long like that. i think i got a better map for ya if you want it
Old 07-15-2009, 10:37 PM
  #734
sure e-mail me only thing is my boost gauge says im boosting like 15 prolly i let off one i seen it go past 10 psi.. i don't under stand ive got my boost controller turned all the way down and my wg spring is only .6 bar 8.7 psi.... hmm kinda scaryy
Old 07-15-2009, 10:43 PM
  #735
umm yea it deffinatly hit 15 psi i think i should take the MBC off mayb its messed up since i bought it used there is no way i should be boosting over the wg spring?
Old 07-15-2009, 10:45 PM
  #736
if your hitting 15 you may have a pinched vac line going to your wastegate or a barb fitting loose on the wastegate. just incase try taking the boost controller off the car to make sure that its not that.
Old 07-15-2009, 10:47 PM
  #737
whats your email?
Old 07-15-2009, 10:50 PM
  #738
hondgangsta@hotmail.com FTL
  #739
lmfao....i keep forgetting that....lol
Old 07-15-2009, 10:54 PM
  #740
you have mail sir
Quick Reply: M=tuned Turbo kit : little update for now
