M=tuned Turbo kit : little update for now
Old 07-16-2009, 10:05 PM
  #781
crush02342002's Avatar
have you tried that map?
crush02342002 is offline
Old 07-16-2009, 10:21 PM
  #782
weezyfbayba's Avatar
i was gonna but.... if ecko keeps messsin up his o2's wouldint mine do the same?
weezyfbayba is offline
  #783
the map is for 8 psi correct?
Old 07-16-2009, 10:56 PM
  #784
it should be good for up to 11psi...after that its kinda up in the air...iv gone up to 14psi on a very early version of that map, now i dont know. i wouldnt trust it for that high to be honest with you.
Old 07-16-2009, 11:16 PM
  #785
im just running 8 psi
when i go up to 11 psi is when im gettin tuned
Old 07-17-2009, 02:29 AM
  #786
ok so i went out and did a couple pull's today after work and 3rd gear pulls nice and strong 4th gear the boost break's up pretty good but 5th pull's nice and strong
think its the tune? im gonna try ur basemap crush
Old 07-17-2009, 02:44 AM
  #787
all4degame's Avatar
man dude, you are whommping on your car pretty hard!
all4degame is offline
Old 07-17-2009, 02:53 AM
  #788
it may or may not...id need datalogs to figure it out...gotta see what the afrs are doing. from the sound of it seems like its something els since it was only in 4th...idk...it could be a world of things...need more info
Old 07-17-2009, 03:07 AM
  #789
just went and put ur tune on it and did a 4th gear pull... no break up at all
and im not whommping on my car.... ive yet to even go WOT yet i was just slowly getting on boost in each gear and noticed the 4th gear prob
also before in boost i was around 10.5 now with ur tune crush il at like 11.5-12 much better!
Old 07-17-2009, 03:36 AM
  #790
i do what i can...peeps dont think so but i can tune a little bit...ima offer e-tuning on my website.
Old 07-17-2009, 04:11 AM
  #791
im deff gonna recommend you ! but yea tomorrow ill ease it to half throttle or a little more in 4th and make sure i don't feel the break up anymore... it didin't stall on me either like when i come outta a gear... but i only took it around the block sooo tomorrow ill hit u up with an update
Old 07-17-2009, 08:20 PM
  #792
ptguy08's Avatar
hey doodz, justin wants to know if he can remove the top oil line with no problem, hes at work, and he wants to make sure its not pressurized and gona go all over the place
ptguy08 is offline
Old 07-17-2009, 08:30 PM
  #793
ecko04's Avatar
The car is off, oil has already filtered through the turbo so he can take it off, there may be a slight leak but he can take it off, it isn't pressurized as long as the car isn't running.
ecko04 is offline
Old 07-17-2009, 09:40 PM
  #794
my oil pressure shows it at like 5 or 6 at idle but once im cruiseing it shows me around 38-40
Old 07-17-2009, 11:40 PM
  #795
all4degame's Avatar
what oil are you using right now man?
Old 07-18-2009, 12:01 AM
  #796
thats a little low bro...something isnt right...the lowest you should see at one time is 8psi. check for leaks, check oil level, check condition of oil. if its gets any lower dont run the car cause something is wrong.
Old 07-18-2009, 12:09 AM
  #797
ecko04's Avatar
The lowest I see is around 8, I might see 7 every blue moon but normally 9 and higher.
ecko04 is offline
Old 07-18-2009, 12:12 AM
  #798
9psi and up with what i got but i did once touch for a sec into 8psi...
i dont mean to scare you justin but just ask Kevin what happens and i dont want to see it happen again
Old 07-18-2009, 12:15 AM
  #799
yea well my gauge isint digital... but ill check for leak's i think there is a small leak at the fitting that i have going in to the head
Old 07-18-2009, 12:18 AM
  #800
ahh...ok...well its prolly just a fluke or just not reading it right or just not a very accurate gauge...idk but still keep an eye on it, if it goes any lower then it would be a good idea to stop running the car till you figure it out.
Quick Reply: M=tuned Turbo kit : little update for now
