M=tuned Turbo kit : little update for now
#842
Originally Posted by rangerryda
check your rack and pinion bolts in the undercarriage. they have a nut on top that has to be held to properly tighten them.
#843
ok well all of a sudden my afr's went to 10$ at idle! so i used the solus i have at work.... maff was ok.... primary o2 sensor was fine but the secondary o2 sensor had no volts had to order one was 90$ also my brand new step 2 colder plugs are blacker then anything just bought another set for when i go get tuned wensday ( as long as this o2 sensor fix's my rich prob) soo yea... bad day car is at my work had 2 get a ride home
#844
also now i gotta go do a clutch on a tc in my garage by my self going to pull an all nighter so i can have it done by tomorrow after noon then go fix my car (hopefully) then drive to get tuned wen's........ a long azz 48 hours ahead of me
#848
btw as far as i know the secondary shouldnt affect tune very much at all...its primary function is to monitor the catalytic converter, how ever i think that the two 02 sensors are linked somehow (not exactly hardwired to each other but the ecu may use both readings to come up with a better fueling stratigy...could be way off on this though)
#850
the primary was getting good connection maf sensor also... the plugs were black i changed them and did nothing....... so im getting new step 2 colder plugs tomorrow from my friend... a new secondary o2 sensor then tune on wensday... and doesint a vac leak make you go lean? the tuner told me its either an o2 sensor / maf sensor.. or possibly the plugs
#851
also crush its ur tune that made the 02 sensor die the tune i was useing from exdos i never threw a code or ran rich at all just had break up in boost ima switch tunes and stay outta boost as long as the o2 sensor fix's it
#852
Originally Posted by all4degame
dang man, already crapped out on your o2 sensor?
#853
#855
no i didint throw that code i kept throwing system to rich and crankshaft pos sensor...... and on the scanner it read the primary 02... nothing was happening with the secondary..... thats the only thing i could find
#857
btw i just went back and looked at the instructions and how the wireing is done...if the boomslang harness wires it like its shown on the AEM instructions then it doesnt intercept the signal but taps into it...
also i could have sworn you said secondary 02 sensor.
#858
#860
yes i know the primary o2 sensor is reading fine the secondary o2 is getting no voltage at all
btw if you get a chance justin send me that tune you have....i want to make sure it is my tune and nothing has changed on it...iv got two tc's running on my tune and nothing like this has happend so far. not even their primary 02 sensors have failed on em.
