manifold quick fix
Old 02-20-2009 | 04:11 AM
Troys_tc's Avatar
Default manifold quick fix
can I use rvt to fix a small crack on my exhaust manifold for a tempory fix until I can get it welded
Old 02-20-2009 | 05:05 AM
Troys_tc's Avatar
the reason I ask is its a little exhaust leak on one of the welds, and I was thinking of putting some rvt on it and throwing some header paint on that to make it look ok for now
Old 02-20-2009 | 05:30 AM
m6ar2cel6oTC's Avatar
no will not work.
Old 02-20-2009 | 05:32 AM
Troys_tc's Avatar
What abot that mirical epoxy that summit sells? Its rated to 1350 degrees
Old 02-20-2009 | 05:43 AM
yuh it wont melt but probably blow off just go it fixed. or pm me and i can get you a manifold for cheap
Old 02-20-2009 | 05:54 AM
aen's Avatar
aen
just let it leak until you get it welded, it's no biggy unless your manifold is like in half. haha
there isn't much that can withstand that pressure and heat.
Old 02-20-2009 | 06:15 AM
Troys_tc's Avatar
I don't about the cosmetic effect of the crack, I just don't want it to get worse, so does anyone know of a temp fix to a small crack?
Old 02-20-2009 | 03:41 PM
THansenite's Avatar
Hot glue or duct tape.
Old 02-20-2009 | 03:47 PM
TurboToyotas's Avatar
go to a local muffler shop....have them mig weld the leak. Just prep the spot a little before they weld it...
Yes its a ghetto temp fix. But prepping it will help it last that much longer.
Regards-
Todd
Old 02-20-2009 | 03:48 PM
Troys_tc's Avatar
I was thinking superglue would be better, atleast then I could catch a buzz from the fumes, j/k
http://www.scpraceparts.com/circle_t...gf-2-part.html
that is a link to that epoxy I was talking about, tell me what everone thinks as being a possible fix
Old 02-20-2009 | 04:44 PM
THansenite's Avatar
I wonder if JB Weld would be able to withstand the heat? That stuff works pretty well on a variety of applications.
Old 02-20-2009 | 04:52 PM
OuterHeaven's Avatar
JB weld is only like 400 degrees. That link up there might work but I would still not want to trust it. I think it should really be able to withstand 2000+ degrees in order to work on a turbo manifold. Now a little exhaust leak on your s-pipe could probably be fixed by the about link if prepped properly.
Old 02-20-2009 | 05:08 PM
ippskidder's Avatar
1UP Crew
Nope it would just crack from the heat ^^
I tried using it, when I had a bad exhaust manifold/turbo gasket.
It just made for a messy engine bay, lol.
Just take it to an exhaust shop and get it fixed.
Old 02-20-2009 | 05:10 PM
ippskidder's Avatar
1UP Crew
Well... according to my egt gauge, when i'm boosting i'm at about 1200 degrees (F).
If memory serves me right.
Old 02-20-2009 | 05:15 PM
draxcaliber's Avatar
order some of billy mays mighty putty! that stuff can do anything!
Old 02-20-2009 | 09:58 PM
scikotictc232's Avatar
if u wanna pay shipping id fix it for free.
Old 02-21-2009 | 12:01 AM
Troys_tc's Avatar
Does anyone know of any epoxys good to 2000 degrees?
mc1114
Scion tC 1G Aero & Exterior
04-23-2020 11:34 PM
alexxfender
04-01-2015 04:06 PM
CPL_Radar
03-05-2015 06:42 AM
Minsk99
03-28-2004 10:50 AM
sixtyspokes
02-06-2004 01:32 PM
