Massive S/C Build ~~ PRELIM NUMBERS INSIDE!
Old 07-08-2006, 11:44 PM
  #361
kytc's Avatar
It's a 4in x 6in barrel. Here's the kit:
http://www.tweakit.net/shop/product_...roducts_id=643
kytc is offline
Old 07-08-2006, 11:47 PM
  #362
sallad's Avatar
Congrats man I can't wait to hear it, oh I'm still selling the Tc and getting an 03 IS300 instead of my original plan of teh 95' supra. I am going S/C it also.
sallad is offline
Old 07-08-2006, 11:50 PM
  #363
BlkSandPrlTurbotC's Avatar
To ANYONE JUST now joining the thread to see the pics/vid here ya go again
Originally Posted by kytc
Here's a video of the BOV:
BlkSandPrlTurbotC is offline
Old 07-08-2006, 11:56 PM
  #364
KCTTC's Avatar
How come you didn't go with a bigger core. It looks like you have plenty of room.
KCTTC is offline
Old 07-08-2006, 11:57 PM
  #365
-NEMESIS-'s Avatar
wow!!! that is not what i expected it to look like! but wow again! bov sounds good!
-NEMESIS- is offline
Old 07-09-2006, 12:02 AM
  #366
Defined3
SkaTG2k3's Avatar
amazing... i am assuming however that if i was to get a ZPI intake, i could not keep my optima yellowtop in the same location...
SkaTG2k3 is offline
Old 07-09-2006, 12:03 AM
  #367
-NEMESIS-'s Avatar
Where is the breather hose from the driver side of the valve cover?
Old 07-09-2006, 12:33 AM
  #368
KCTTC's Avatar
Piping should, I'm not certain but I think from measuring that ZPI should be able to fit the pipe in right where the stock is once they clock the s/c housing just a bit. If they get in there and that won't work then I'll let them just do what works. Whatever they do it will be substantial less piping then the FMIC, probably a 1/4 of the piping if not less. I got the intercooler for about $1050 shipped from tweakit performance in Australia and ZPI quoted me 3 hrs or less at $95 per hour plus $150 for them to get the pipe and weld it to the intercooler barrel. So if you say 3 hrs it ends up being around $1450-2000.
It doesn't look like it came out like you originally planned. I thought the whole point of using the liquid to air intercooler was to use less piping. It looks to me like you have almost as much piping as a front mount.
Jeremy
KCTTC is offline
Old 07-09-2006, 01:04 AM
  #369
kytc's Avatar
I didn't go with the bigger core b/c there's definitely no more room for a bigger one. It did use less piping, not as much as I'd originally thought. With the s/c there's basically no room to work with where it's at, so this is probably the shortest piping as you're gonna have. The boost loss is no big deal, I'll just get a pulley to make it up.
kytc is offline
Old 07-09-2006, 01:06 AM
  #370
kytc's Avatar
The breather valve has always been plugged off, even after the dealer installed the s/c. I'm gonna get a catch can and route the two breather valves into the exhaust eventually.
The pictures don't really do the kit justice, you'd have to see the car and ride in it before and after to really feel how much different it is.
kytc is offline
Old 07-09-2006, 01:09 AM
  #371
KAD
g0t_rice's Avatar
absolute creamage
g0t_rice is offline
Old 07-09-2006, 01:50 AM
  #372
KCTTC's Avatar
I am not trying to down grade your setup but it looks like they rushed right through this project. I guess I don't understand why they mig welded all your piping when all there turbo systems have nice tig welds. Why did they use silicone couplers to make up for bends they could not make? You could have gone up at least one core size by welding an aluminum elbow directly on the supercharger and using one silicone coupler instead of the two couplers and the large radius bend they used.
Jeremy
KCTTC is offline
Old 07-09-2006, 01:57 AM
  #373
Music City Scions
rhythmnsmoke's Avatar
Jeremy
I think that would have been substantially MORE difficult to complete, therefore increasing the cost.
Congrats bro. Now vids of the car under load would be viscious.
rhythmnsmoke is offline
Old 07-09-2006, 02:26 AM
  #374
kytc's Avatar
It sounds to me like you are. I had the option of welding onto the s/c however I didn't want to do that because if I ever had problems, wanted to sell the s/c, or w/e it would be a biscuit to do. For the extensive work that had to be done the kit is beautiful and works MUCH better than expected.
They could've made and welded the bends that they used the couplers for however it would've been impossible to install or uninstall. A larger barrel is not needed, look at Sciondad's setup, he's using the same barrel and running a stage 1.
kytc is offline
Old 07-09-2006, 02:49 AM
  #375
KCTTC's Avatar
Sorry I did not mean to come off like that. I just expected more. If you like it and it works I guess thats all that matters.
Jeremy
KCTTC is offline
Old 07-09-2006, 02:58 AM
  #376
kytc's Avatar
There's probably not another person that is as big of a perfectionist as me when it comes to cars. If there was a better way to do this that was feasible it would've been done, I promise you that.
kytc is offline
Old 07-09-2006, 03:21 AM
  #377
jwaggz82's Avatar
One thing that im wondering about was .... now that you have a bov instead of a bpv ... how is it reading the correct amount of air if its being blown out instead of recirculated?
jwaggz82 is offline
Old 07-09-2006, 04:30 AM
  #378
kytc's Avatar
It actually hasn't been that big of a problem. It throws it off just a touch but it's not bad. The emanage ultimate will completely fix it. The biggest problem is just the idle is so rich it's ridiculous. At idle the afr's stay at 10 so it's a pain to keep alive at the stop light. After a day's experience afr's at cruise range from 14.7-15.2, Full throttle 11-13, idle 10. I'm actually pretty impressed with the TRD reflash and how it's managing it so well with the maf so messed up from the custom intake and it being so close to the s/c and a bov on it. Charles is ordering the ultimate for me Monday and I'll be out of town next week so three weeks from today is ultimate, injectors, and upped boost. I'm going to try and hook the AEM wideband up to it though and do the auto program if possible until I go to Charles.
I had my first major scare tonight on the way home, lol. I had just gotten on it and all of a sudden the car just starts going crazy, afr's drop to 10 and it sounds like a helicopter landing. So I limp home and found that I'd experienced my first charge pipe blow off. Needless to say it's ridiculously tight now and some t-bolt clamps are being ordered tomorrow.
kytc is offline
Old 07-09-2006, 04:39 AM
  #379
davedavetC's Avatar
wow tjhat looks insane!!! congrats, MORE VIDS!!!
davedavetC is offline
Old 07-09-2006, 04:41 AM
  #380
kytc's Avatar
My gf took another tonight of the bov inside the car when I was taking her home I'll try and get it up tomorrow.
kytc is offline
Quick Reply: Massive S/C Build ~~ PRELIM NUMBERS INSIDE!
