Max HP Based on CC's/PSI/Duty
After searching for a while I havent really come up with a good answer.
Using a fuel injector calulator I cam up with:
Engine Crank HP = 500
BSFC = .60 Turbo Application
# Injectors = 4
Max Duty Cycle = 80%
Fuel Pressure = 45psi
cc's Needed = 968.75
So obv I have seen tC's on here with smaller cc injectors than that and are still pushing 450-550whp. Is this due to the 1:1 FPR??????
Using a fuel pressure change calculator and changing the pressure to 65psi on a 700cc injector (Adjusted with the 1:1 fpr for 20psi of boost pressure)....a 700cc injector would have the same output of a 855cc injector?
Pretty much I am trying to decide what the max HP I can get out of a 700cc injector with a 1:1 FPR. I will be running 20psi of boost pressure and expect to get anywhere from 400-500whp. Any thought will help.
# Injectors = 4
im running rc 650cc injectors, walbro 255lph pump, and stock everything else fuelwise. im making 411whp on a mustang dyno,(450-470 dynojet) @ around 80% duty cycle. im also running 100% meth injection. not the best way to make that much power, but it will work until i get a return fuel setup.
umnitza
09-01-2015 09:06 PM
carid
08-31-2015 12:17 PM
