me beautiful stage 3 block
Old 04-19-2007, 03:11 PM
  #221
Music City Scions
rhythmnsmoke's Avatar
^^Change the "C" clamps while you are at it Brett. Kenny had the same problem on Brian (Jesters) car, and he changed the clamps to more Heavy duty type.
rhythmnsmoke is offline
Old 04-19-2007, 03:32 PM
  #222
malloynx's Avatar
your going to need to bead-roll your pipes or run some t-bolts
malloynx is offline
Old 04-19-2007, 03:37 PM
  #223
318_tC's Avatar
what kinda 60 foot? you should be pulling some better times then that with that mph. Congrats!!!!
ZPI kit doesnt come with tbolts???????
318_tC is offline
Old 04-19-2007, 03:40 PM
  #224
Music City Scions
106 MPH is a High 12sec run.
I ran 105mph Last Tuesday on 8.9 PSI and Worn Out Drag Radials by the way...
Old 04-19-2007, 03:43 PM
  #225
318_tC's Avatar
i trapped high then 106, and im untuned....
318_tC is offline
Old 04-19-2007, 03:46 PM
  #226
Dyltone's Avatar
I smell group buy on the Clutchmasters stage 7....
I'm in!
Dyltone is offline
Old 04-19-2007, 04:16 PM
  #227
malloynx's Avatar
tilton FTW...
malloynx is offline
Old 04-19-2007, 04:28 PM
  #228
Brett's Avatar
im probably going back on friday to se if i can get my times to drop. btw travis what was your et?
Brett is offline
Old 04-19-2007, 04:32 PM
  #229
Brett's Avatar
I'm in!
this is th one i need http://www.autocarparts.com/part/1759/496/
Brett is offline
Old 04-19-2007, 04:43 PM
  #230
malloynx's Avatar
SPEC's new + line of clutches are awesome. they hold the torque very well and are super streetable. here is one to consider that is a 1/3 of the cost for the CM stage 7.
http://www.horsepowerfreaks.com/pric...mport_Stage_3+
this clutch is good to 600ft lbs of torque. this is the clutch i'm going with.
malloynx is offline
Old 04-19-2007, 04:46 PM
  #231
Music City Scions
Only got two runs in, and having one DR at 40 PSI (the one that actually counts) and the other one at 20 PSI doesn't make for a good ET. Add the fact that the car runs 10.0 A/F ration at WOT and the DR's are over a year old, and the one that was at 40 PSI looked like a race slick from being used at Last years Scion Shootout = 13 sec runs with 12sec trapspeeds....lol.
That was my first time at the 1/4 track with the car. Only two runs and then the track closed, so I was ____ed as it takes an HR for me to get there.
I'm going back Tues, and will get there early enough this time to check all my tire pressures and find my rhythm with the car. I just installed the Turbo XS boost controller last night. So now the car holds steady at 10.1 PSI instead of 8.9 PSI. Spikes a sec to 11.6 and holds at 10.1 so we will see how she Putt Putt down the 1320.
PS...Even with my problems that night, I was still faster than this modded GTO...
Old 04-19-2007, 04:49 PM
  #232
StealthScion's Avatar
nice. but i just think its funny how the wastegate on that manifold is in a totally useless position.
"An external wastegate requires a specially constructed turbo manifold with a dedicated runner going to the wastegate"....
that wastegate only relievs exhaust from 2-3 cylinders tops...
StealthScion is offline
Old 04-19-2007, 05:01 PM
  #233
318_tC's Avatar
so what did u run travis
318_tC is offline
Old 04-19-2007, 05:08 PM
  #234
Music City Scions
What manifold are you talking about? What difference does it make if it did it from all 4 anyway, relieving pressure is just that....relieving pressure.
Old 04-19-2007, 05:12 PM
  #235
Music City Scions
I said 13 sec ET's with 12 sec Trapspeeds.
Not worthy of making a post about 13 sec runs. So, now that the car is holding a REAL 10 PSI, I will run it and find what she does. THEN I will post about those times. Won't have time to Retune it before going to the track though, so still will be running 10.0 A/F Ratio at WOT.
Old 04-19-2007, 05:14 PM
  #236
318_tC's Avatar
what are you trapping...
318_tC is offline
Old 04-19-2007, 05:18 PM
  #237
Whocares05050's Avatar
Funny travis, ZPI must have a horrible setup to be running 12's from more than a couple customers. I havnt seen a so called " proper stup " in a tC postin up them 1320 times lower than 13's.
Whocares05050 is offline
Old 04-19-2007, 05:29 PM
  #238
Music City Scions
The only NON 13sec run I know of is from Louis on a Stage 0 with regular street tires. I still think his Stage 0 is a High 13sec car though. That was his first time at the track with a turbo car ever, and his time was like 14.3-14.5.
PS...oh, one more car, but it was an Auto w/Stage 0 still. I think he ran a 14.8 or something all the while still beating a S/C Cobra Mustang. It was a recent thread.
Old 04-19-2007, 05:58 PM
  #239
wow rythmn, with your extensive knowledge, i'm surprised you even had to ask that...
whats the function of a wastegate? to help regulate boost by diverting exhaust away from the turbine, right? well, if its only diverting exhaust from 2 or 3 cylinders, then its not very effectively regulating boost is it?
i'm not going to sit here and aruge with all you ZPI fans, but anyone who knows turbo systems knows that that manifold isn't very well designed/constructed. i can imagine lots of boost spikes and over boosting. thats all.
Old 04-19-2007, 06:06 PM
  #240
Music City Scions
I never claimed to know everything....People only Assume I know a lot...
HOWEVER....You are Wrong. And it's understandable that you don't know because you don't actually OWN a ZPI kit. Sorry, but you do not get Boost Spikes all over and Over Boosting with this manifold. With just running off the WG spring, with a 10 PSI spring on our car, when I punched it, it jumped to 10 PSI, but held at 8.9 PSI. Ran this way for over a year, only till yesterday I just installed a boost controller.
Don't assume how it works just by looking at it. It's quite the opposite that you described. "Effectively" regulating boost you say right? Not well designed you said, yet it does exactly what your idea of "Effectively Regulating Boost" is. I have YET to see our car....OR any other ZPI turbo car Boost PAST what the spring in it is set too.
PS....You can't argue with Assumption against someone who is speaking from Experience.
Quick Reply: me beautiful stage 3 block
