Megan Header and Supercharger?
Has anyone done this? The only reason I ask is I just bought the megan header, and I'm concerned as to whehter the shaft that goes to the supercharger will clear the pipes, because the two to the right are slightly angled up.
Works fine, Tikbhoy has done is sucessfully.
Read more here.
https://www.scionlife.com/forums/viewtopic.php?t=98344
Read more here.
Re: Megan Header and Supercharger?
you will have to get a set of nut/bolt/washer/locknut for the lower brackets. you cant use the OEM bolts on the header.
BE VERY CAREFULL taking out the AFR sensor, mine came out stripped. use alot of WD40 and some sweet kisses or else your going to be 200$ broke.
Originally Posted by duma
just make sure you do it before the sc install.
another thing is the header gets really hot! so i suggest putting heat blanket/wrapped/coated to it.
good luck
Why wouldn't the OE bolts work with the lower bracket. From the install pics of the DC header, they seem to, and the megan header looks identical in that regard. If the stock ones won't work, then what size bolt will I need?
the brakets are there for a reason, take your time and do it right.
I know this is a bit off topic, but i've got a brand new Megan Header w/o cat for sale. 150 shipped. Locals can pick it up if they want for less. PM or email celica6spd@cfl.rr.com
rain7905643
06-13-2018 05:29 AM
CrowJenkins
10-09-2015 10:47 PM
kslim619
09-18-2015 06:54 PM
