More torque from TRD supercharger
Old 01-05-2006, 03:32 PM
N.G.S.O.
zoltiz's Avatar
ZPI pulley showed 21whp / 10wtq on my car. So all in all I have about 46% gain over stock with SC/pulley/stock exhaust.
zoltiz is offline
Old 01-05-2006, 04:49 PM
tikbhoy's Avatar
How much torque do people really want this days ? 180ft/lb is alot already! I have no plans of hualing a boat with more torque.
or are you looking for head jerking power once boost tops out ? Centrifugal dyno's are pretty
tikbhoy is offline
Old 01-05-2006, 05:19 PM
Scion Society
TimmyT's Avatar
a lot of vic owners would kill for those torque numbers
180 is just about right for the tC. at 180 you can put some gummy tires on and not be too hard on your axles. Too much torque + some sticky tires = broken parts.
TimmyT is offline
Old 01-05-2006, 05:37 PM
FLINT's Avatar
you will notice a big difference i u get a light flywheel and a ingalls etd. the etd helps u put aalll your torque to the ground instead of some torque without it. the flywheel will kick your power in sooner with the faster excel that it does. i hope somebody tries this.
FLINT is offline
Old 01-05-2006, 07:16 PM
HighlanderMac's Avatar
I will tell you guys this. As long as there is no Quaife you may not want all these torque numbers. I am at 197ft-lbs and there is NO WAY I can full throttle in 1st gear...
OutCrnrU you need to get that thing dynoed now. I cant wait to see where you are at. You should have passed me with that addition, unless that S-Pipe is really that restrictive.. Cause as of now, you and I are both restricted at one point. Me at the header and you at the S-Pipe... hehehe..
HighlanderMac is offline
Old 01-05-2006, 08:15 PM
OutCrnrU's Avatar
i know i will try to get it dynoed again but its so expensive i cant make any promises... also i was gonna try to get the s-pipe before i dyno again, i believe the stock s-pipe is really holding me up right now, i will see what i can do in the next couple of weeks.
OutCrnrU is offline
Old 01-05-2006, 08:22 PM
Aight man.. .take your time. I am hoping to get my header here in the next month.. CROSS FINGERS!!!!!
Old 01-06-2006, 04:04 PM
tjbartjr's Avatar
What about replacing the stock cams? N/A cams in a forced induction application is less than ideal, I would think.
tjbartjr is offline
Old 01-06-2006, 07:07 PM
OutCrnrU's Avatar
if you could tell me where to get fi cams for the tc i would buy them tomorrow but to my knowledge nobody makes them yet
OutCrnrU is offline
Old 01-06-2006, 07:16 PM
Scion Society
TimmyT's Avatar
You should ask the Dezod guys about that. I thought they were working with crower or someone to produce FI application cams.
TimmyT is offline
Wrencher
03-12-2023 04:54 AM
AMS13
08-20-2015 07:26 PM
Angelj85
08-18-2015 01:27 AM
5N1PE5
08-03-2015 11:25 AM
gqdabien
07-30-2015 07:04 PM
Quick Reply: More torque from TRD supercharger
