Most Powerful Turbo Kit
#142
Team No Limitz
Originally Posted by Mr_Meaty
Honestly, with you being in colorado (higher elevation) you probably wont' get 300hp at 10psi, so yeah, a good tune and you should be good.
I just think it would be beneficial to have the OPTION of lower boost just incase something is not running right at the higher boost level.
#143
Originally Posted by Simplyscion
ohh yea, also, you may wanna start with a smaller wg spring like everyone else is telling you. You can always turn the boost up with a smaller spring, cant go backwards though...just some food for thought
#144
Team No Limitz
id say anywhere from 270-290 depending on how aggressive the tune is...also, if i were you id go and get your car dynod right now before you install the kit so at least you have a baseline and you can really see what your gaining from the kit. Dyno's all read differently so its a bad starting point to just dyno and have those numbers from the turbo install without anything to compare it too...if your gonna do that also make sure you are running on the same dyno before and after
#145
#146
No, upping the boost to high (hight then 10 I think) will blow you pistons and snap your rods.
I dont' think a thicker head gasket is a safe way to lower yoru compression. I believe that has been discussed before.
If you want safety, or to really up the boost, get rods, bearings and low compression pistons designed for boost. Dezod has all that. Parts plus installs should probably run around $2k, but don't quote me on that.
#147
dude ive been running 10psi for over a year and a half. its fine.
#149
You can run higher boost levels than 10psi, just depends on a few things.
1. What turbo
2. How good your tune is.
I have a few cars running anywhere between 11-14psi on stock motors making 360-392whp respectively in the hot arizona summer with out any issues. And the cars get beat to death on a daily basis.
But all the owners realize what could happen. Plus they all want an excuse to build there motors anyways.
have fun
regards-
Todd
1. What turbo
have fun
regards-
Todd
#151
1. What turbo
have fun
regards-
Todd
1. What turbo
have fun
regards-
Todd
#152
Your making me want to get ballzy with my setup!
cessblood
09-15-2015 06:50 AM
my06tc
06-25-2015 12:18 AM
