my dyno pull
my dyno pull
here are my mods
1. custom cai
2. mmw headers and s-pipe
3. custom s-pipe 2.5 inch exhaust
4. unorthodox lighted crank pully
5. nst water pump pully and alternator pully
6. lighted flywheel and clutchmasters 6puck
7. nology wires
8. unichip
9. 75 shot
http://www.youtube.com/watch?v=v3t5ms4Zheo
these are my numbers without the unichip and also my bottle pressure was only at around 800 psi. If i was at 950-1000 psi I would have hit 300whp Tell me what u guys think thanks
1. custom cai
7. nology wires
8. unichip
9. 75 shot
you wasted your money on the nology wires, toyota's coil on plug design is apparently the best you can have, so you should put that back to stock unless you just like the way they look for car shows or something.
would be curious to see what you make without the nitrous.
my #s
i made 191 whp on motor. so in all actuatility i made about 100 extra horse with 75 shot. heres a couple things to keep in mind.
1. first of all this was a mustang dyno so its legit.
2. my cold air has no filter and my exaust is just 2.5 straight pipe, no resonator,cat or muffler which works really well with spray.
3. my car is gutted which u have to calculate the weight on the dyno so if my car weighed the full 2905 i probably would have only made about 165 to 170 to the wheels. If u want to c what i did to lighten the car go to the topic "scion tc diet plan" my car weighs in at only a lil over 2500 lbs.
I guess tire size is roughly the same as final drive ratio
How did weight affect the dyno numbers? If weight is an element to the final readings, can't you enter in whatever weight you want before the run, making up for any weight reduction?
Re: weight
Originally Posted by hooperstar
you are correct u have to enter the correct weight to get and actuate reading so we entered 2700 that was with the person in the car.
Also 190whp with no nitrous! I think they need to fix their dyno cuz it's off. Plus the fact that mustang dyno's read lower compared to others so that means with no nitrous your car is making over 200whp on just those mods. That's hard to believe. I'm not calling you a liar or anything cuz you have video but I think their dyno is messed up.
