My Scion.....340.6whp on 12 psi.....ran 12.4 quarter mile
#41
Originally Posted by DaGreat1
15x7 with the psi i believe at 16....they i dont know for some reason i felt like i was grippin better with the BF DR's i also have the new ZPI....limiter...that helps with the wheel hopping
#43
Vibration?
Performance ?
Pics?
#44
welll right now .....
New turbo
New fuel pump
rebuild motor
Pistons 8:5:1
Rods
Mains
Bearings
Shortblock machine assembly work
3 inch downpipe
electrical cut off valve
water/meth injection
Greddy Prefec Boost controller
Tial BOV 50mm
Greddy manifold
New piping
New intercooler
NOS Kit...still not finsh installing it
and more just cant think of everything right now
New turbo
New fuel pump
rebuild motor
Pistons 8:5:1
Rods
Mains
Bearings
3 inch downpipe
Tial BOV 50mm
Greddy manifold
New piping
New intercooler
#48
You have the limiter....Awesome! Is that the only form of engine bracing you have, or is it in conjunction with the ETD as well.
#52
Originally Posted by mikescion
etsnet , his turbo has a internal wastegate no external...
Originally Posted by Simplyscion
etsnet...the short block machining was probly just the nothcing needed to accept the new rods
The notching then is done whenever anyone gets new rods I would assume so it's not a big thing? So he has like an = to a stage2 ZPI short block.
#54
Originally Posted by j3st3r
Originally Posted by Brett
^^its not called an engine limiter. its "The Big Black Stiffy".
#56
How to preload
1. put shifter in first gear
2. you bring the engine to your desired launch rpm
3. pull up on emergency brake while keeping your thumb on the button so it wont lock
4. release the clutch up to the point where it starts to grab (this takes the slack out of the drivetrain therefor reducing the initial shock introduced to all associated drivetrain parts)
5. when ready to launch, simultaneously release the clutch and e-brake
6. you have just launched with preload
#57
Originally Posted by Kumitsu
can anybody explain to me , how this preloading can be achieved ? step by step
DaGreat1, you planning on going to the shootout in July?
#59
When?
Where?
Kentucky somewhere around ZPI. It's gonna be in July sometime. I'm sure they'll be other guys from NY and that area going and you can all travel down.
