My turbo car is throwing cel light code PO300 and 301
The Code is PO 300 and 301, Cylinder 1 misfire anybody have any idea what might of trigger this, any help or opinion would be greatful..
check your plugs, check your ignition map (rule of thumb 1degree of retard for every psi of boost...just a reference), im not familiar with greddy management so check your software and make sure your running whatever software that is best suited for the tc (if there is different software)
Originally Posted by TheFantasticG
P0300: Random/Multiple Cylinder Misfire Detected
P0301: Cylinder #1 — Misfire Detected
Is there not a list of CEL codes on this forum?
thats random and cylinder 1
check plugs first and report back
if u dont know what ur looking for take a pic of the plugs and post it
Check the injector, coil pack or the spark plugs. Try switching them around and see if the misfire move to another cylinder that will help you find out the cause of the missfire. I can stop by and help you if you want bro.
Also Davedave hit me up.
I change the plugs now it idle better, and so far no cel yet, I will give it another week of driving. afr for idle is 15-16-17 afr for cruising is 14-15 afr for boost is 11.2-12.3 at 8-10 psi
