My Turbonetics Dyno Numbers Posted, SUCKED 200WHP
Originally Posted by 2LoTc
so much for bolt on and go...
that truly does sucketh.
u have an exhaust, that will add A lot now..
other than that, maybe ditch the chip and get a GOOD tune.
Originally Posted by DTRUONG_112
Originally Posted by MIAPLAYA
I must have missed that....there is definitely something not right with your car...can you post the graph please...are you throwing any codes?
I'm with Peteyd. Sounds like you need a tune.
Why are people dynoing in 3rd gear? I thought we where suppose to dyno in 4th gear. I don't understand this is the second one done in 3rd.
91 octane. Running the NGK iridiums gapped at about .28. No other mods except TRD exhaust which shouldt affect the numbers.
I need more HP miaplaya. Help me out man, reggie wont be in til monday...
Well theres a couple things we could do...without the AFR chart its not going to be easy though. I need to see the fuel curve to determine whats going on. If possible would you conisder removing the exhaust and running the dyno again just for reference? Another possiblity is to disconnect the primary O2 sensor and run the dyno again. Is the O2 extender on the secondary O2 sensor? (it should be)
The o2 extender is on the second sensor. Man, trying to get a dyno was hard enough. What would happened if I remove the primary o2 sensor, how would it affect the numbers? I can try to remove the exhaust and run it again but I'll have to schedule a dyno run again.
if your a/f ratio went to 10 to 1 you should have thrown a cel!. that sets your car in rich mode. my car right now throws cel's when i hit wot and my af hits 10psi and all its throwing is super rich mode.
yeah make sure your maf is installed perfectly straight. i ran into that problem with mine (though my emanage threw a code my engine did not). i had my cocked to the side a little and it threw my tune way off
at 8psi with stock exhaust you should be around 210 ish until you get it retuned. once you get to a unichip tuner they can tune you for 230ish at 8 psi, bump up the pressure and you will be good to go with a new tune.
Turbonetics add's state that they got 244 whp on a stock car. So there must be a reason behind this other then just a tune. Plus there are so many other turbonetics cars that are putting down really high numbers on the stock tune.
