Need help! Car leans out!
Hey guys. Just trying to gt some input And see if anyone else has ever heard if this or seen it? So just got my car back from my tuner/mechanic and we were noticing the car lean out when you depress the brake pedal while sitting in park with car at idle! We checked the brake booster and the check valve, but somehow there is air getting back into the intake manifold? Has any one ever heard of this? Any info would help!
lol no. my car ran ok when it was driveing when i come to a stop to idle it lean'd out. start ur car. let it run. unplug the vac line from the bov. if ur afr's go back to normal. there u go. other than that. check all vacuum line's you got a leak
check the bov do what i said if you have the hks bov. i had the same exact issue ur haveing. the bov failed. if that doesint work. get some MAF cleaner and spray around all the vacuum line's and every coupler!
im running the emanage set up right now. checked the bov... its not that! what we found was that theres a vacumm line coming from the brake booster and going to intake mainfold. we think were getting air fromo there??? but the brake booster and the check valve are checking out ok!
so were still kinda stumped??? dont know exactly how the air is getting into the manifold???
PTUNING
12-11-2014 08:09 PM
PTUNING
12-06-2014 03:58 PM
2fixA
10-06-2003 05:01 PM
