Need help with clutch option please
I am looking at my options right now. I am either going to rebuild the auto trans or just convert to the manual. Im trying to get a price both ways to see what is the better way for me to go.
Anyways if I go manual of course im going to need a new clutch/flywheel combo.
I need some help with all the clutch options.
I will be running the zpi stage 1 kit at 13psi on the auto it put pown 260whp and around the same tourqe #'s
So what kind of numbers could I see with that same turbo setup with the manual trans?
Looking at all the clutch oprions and I just need some help with whats picking what would be best with me.
After searching I see that for the best stock pedal feel I would need a sprung clutch. So would I need a stage 3 clutch?
Also how different does a full face clutch and the puck clutch feel??
Any info whould help me alot!
Thanks guys
Thanks guys
well
i just installed my 9.5 fidanza flywheel and my stage 4 CC 6 puck sprong clutch at first the pedal was pretty stiff but after a week and a half im so use to it kinda feels like stock just a little tighter only thing on mine is when i let off the gas i was hear this rattleing noise think its my Throw out bearing idk i used the one that came with the clutch.... its not affecting anything tho
You might want to reach out to soflotc, he just did a manual swap and probably give some insight on the costs/time involved.
In terms of the clutch, I have stage 3 clutch masters and I'm pretty happy with it. From what I understand it will hold somewhere aounr 320 wtq without excess wear, so if your not planning on bulding out or motor it will be adequate. I also understand that the stage 3 clutch masters have a more 'stock' pedal feel and smoother engagement when comparing with other clutch option. I was used to it within a day,
Weezyfbayba, is that rattling kinda of a chatter? If it is, from what I understand it is prety common on upgraded clutches. I had some chatter on mine (when my clutch pedal was adjusted pretty high). I ended up adjusting the engagment point down and only have a very slight chatter now.
Ok so stay away form the CC stage 4.
How much increase in power do you think I will see switching from the auto trans to the manual? I know there is quite a bit of power lost going though all the parts of the auto.
I would definitely suggest an ACT Modified Street Disc. It is capable of handling 390Ft/Lbs and increases clamp load by 32%. The clutch feels great when daily driving, and has a smooth engagement. I commute 80-100 miles per day and have no complaints. But when i get into boost, it grips like madness too....
http://www.advancedclutch.com/produc...d_id=2682#2682
Hows your auto doin? Tranny headed downhill? Suprisingly (knock on wood) mines held up relatively nicely lol with over a year of abuse on it now If you do the manual swap - sell me your mod valve body lol BTW i still can get thos etrannys for $200 - but they weigh more than i thought so itll be quite a bit to ship
Originally Posted by SoFloTC
i would vote against CC stage 4.
lol only because its only ment for like 300-350 whp you were just learning to drive stick and pushing 400+ hp its ur fault the clutch went out not CC's lol
If you really want the valve body ill sell it to you always like to help some one else out if i can!
Ya i figures shipping the trans would be kinda expensive but thanks anyways for looking!
