need help now someone please
anyone, i need help, i have spent 3k in the motor cp pistons manley rods arp main and head studs acl bearings. stock crank and stock head. last weekend i got the whole motor assembled and in the car.. the motor turned over a couple times but not enough to get the car runing. the battery was dead. i didnt have the money last week to buy a battery, iam also in college so this weekend i come home buy a battery and put it in the car.. now the starter turns but the engine doesnt... which means the engine is sizzed.. cant spell, iam a little upset. so my question is what do i do? can i put some oil in the spark plug hole and try to turn it over? someone please help
Re: need help now someone please
Originally Posted by brett561tc
im confused. how is your starter turning, but your engine not? do you mean that your engine isn't firing?
i wish i could take a video of it.. the motor will not turn at all.. even with a wrench on the crank, but if you put the wrench in the off poistion it will rotate.. i figured out what it was, i believe it is timing. iam guessing the value is hitting the piston.
someone should make a sticky on how to set initial timing when installing the motor. if i remember correctly, it has something to do with people using the wrong mark on the cam gears. if yamaha16 can chime in that would be nice, i think he knows what the problem was.
https://www.scionlife.com/forums/sho...=164921&page=5
Check that whole thread and make sure you check page 4 & 5.
If not do a search for more topics
Yea i think when folks are aligning the marks they are using the Dot with an E by it on the exhaust cam. The exhaust cam has 3 marks, one dot with an I by it, one dot with an E by it, and a hash mark with nothing by it. It needs to be timed to the hash mark. If you REALLY need a pic I guess I can go out in the garage -my cams are laying on a table
I know when I reassembled my engine, I had a hell of a time figuring out which mark the service manual wants you to follow. It wasn't until I took note of crank position that I actually analyzed and figured out which valves should be in the open position and which should be closed that I decided which has mark to use.
Yea as long as people use the toyota service manual then you wont have any issues. Mine fired up it the first few seconds after I primed the oil system. I'm having trouble logging onto photobucket now but my pics on the correct timing marks are posted somewhere.
