Need help with oil feed and return and other turbo stuff
I need help getting some fittings for the oil feed for my t3 t104e journal bearing unit.
I still have the trd s/c tee fitting and oil pan, does anyone know what the fitting on the end of the tee is ? 4 an or 3 an ? I want to try to keep the cost down and reuse the trd t fitting, plus it is a good qaulity fitting t that threads into the block very well ( not like some other t fitting I used before)
for the return I was just going to use a slip adapter for the chra unit to go to the trd tapped oil pan which I think is a 5/8" inlet but am not 100% sure. Would this flow enough ?
Another question
I can't make up my mind being that I am not going with a fmic to start I either getting a Snow Peformance Stage 2 or a AEM Meth injection kit, any thoughts anyone ? I like the safety switch on the snow kit that dumps boost pressure if the flow drops.
got a update turns out 10 an is 5/8" id and 8an is 1/2" id so the 10an oil hose I got did not fit the 1/2" port on the trd pan. So I went out and got 1/2" id Heater hose and a 1/2" npt to 1/2" Barbed fitting and the 1/2" hose fits the trd pan perfect.
AEM
Universal kit includes everything you need for installation.
Progressive, controller-driven 150 PSI pump.
One of Five gallon tank with integral fluid level sensor.
Dash light for system status and low fluid warning.
Alcohol Compatible (up to 50% in solution with water).
Progressive controller, provides boost-dependent variable flow.
Output provided to either decrease timing or boost if the system runs out of fluid or detects an error.
Includes three jets to match your power requirement.
snow perf stage 2
Kit includes:
• 150+ PSI High Volume Pump
• 3 Quart Reservoir
• Digital Variable Controller
• 2 Nozzles To Cover a Wide Range of Horsepower
• All Required Hardware Needed For Installation
• Comprehensive Instructions
i've never seen the AEM one ran but i've heard fantastic things about the snow perf on a few of my friends cars.
snow perf stage 2
Kit includes:
• 3 Quart Reservoir
Yeah I guess it comes down to price, I can get the aem cheaper, both are progressive with a saftey boost kill switch so I'll go with the aem unit. I'm not sure what mix I should do since I'm not using a fmic, would a 50/50 mix be too aggressive ?
As for the size thing, oh well thats part of doing a custom kit, so who wants to buy 24" of 10 an rubber hose and slip on barb fitting
Yeah the AEM kit is REAL nice and now offers 2 different size containers for your Meth. 1 gallon or 5!!!
http://www.dezod.com/cat_water_injection.cfm
my06tc
06-25-2015 12:18 AM
ScionLife Editor
11-25-2014 03:00 PM
