Need Help w/ Oil Pan
iv used red rtv, black rtv, toyota black crap, it all worked. I have yet to have an oil pan not seal with any of these.
just make sure the mateing surfaces are clean of old sealant and oil, oil pan is not bent to hell, also the bolts are tq down to proper specs. you should have no issues.
How difficult is it to remove the oil pan? I have a tapped one coming home for my turbo setup. Last time with my Turbonetics setup, I tapped the hole myself and didnt bother removing the oil pan.
Blow torch. Use some razor blades to cut away any sealant and to separate the pan from the block as well as you can then heat the edges really well and use a flat head screw driver to pry all around.
It's probably the hardest part of installing a turbo kit haha.
SloTC1
08-16-2018 02:45 PM
Klashan
09-24-2015 12:39 PM
