Need a new Turbo, help me decide which one would fit Dezod S1 directly !!
gt3076r 0.82 a/r ftw! will get you to your goals like what the ptuning 500hp is running or the precision 6262 or gt35.. but you dont have to over kill if you dont need to. Hooking up the waterlines isnt hard, it cools the turbo better too but you just have to upgrade your cooling to get rid off the added heat to your system if its a daily driver
yes i'm planning on changing the DP and Sp to 3'' inch later on for sure man.
ACE, are those turbo's compatible to S1 kit ?
i've been thinking, S1 kit uses T3 turbo, does that mean that any turbo with 5 bolt DP pattern and T3 housing will basically bolt right up ?
the garrett gt3076R turbo has a four bolt discharge (downpipe) flange
http://www.turbobygarrett.com/turbob...382_12_new.pdf
however you can search around for a 3076 that is modified for a 5 bolt discharge flange or find an adapter...its still iffy if even after the adapter it will work.
now this may work better if this is the flange in question (gt3071R)
http://www.turbobygarrett.com/turbob...2_3_20_new.pdf
another option is to just buy the center section with the wheels so all you do is swap out the turbin housing and compressor housing if it will fit...thats the key though...i really dont know if it will fit or if some porting will have to be done. and again idk exactly what the stats are of your current turbo.
http://www.turbobygarrett.com/turbob...30/GT3071R.htm
Last edited by Crush Automotive Customs; 08-24-2009 at 04:02 PM. Reason: more info
what crush said.. but yeah most gt30 comes with 4 bolt or vband, if you want you could just change out your downpipe flange to 4 bolt or vband or you could do that x to x adapter flanges or just have some weld on flanges to the turbo exit.. tons of options right there.. usually adapter flanges requires you to do some modifications or if there is a significant change in size of your turbo it might throw out your alignment of your dp but you're gonna be having a new custom 3" dp anyweiz so watever works
Thought this might sell you.... GT3076R on a Dezod S1 kit:
That thing is a friggin beast!!!!
Thread :
https://www.scionlife.com/forums/sho...d.php?t=164029
Thread :
that turbo is nice but its blown.. repairing it and shipping will get me close to what i spoke to Paul about today.
Paul and i are working on a turbo that will specifically meet my needs. But its going to be NON ball bearing. ( as i dont need it much )
now the question is, what is better billet or cast compressor wheel ?
Stronger?
Sometimes, in OE applications, fully-machined wheels can withstand higher centrifugal stresses due to differences in the base material. Forgings are inherently stronger than the typical casting in this respect. However, when Honeywell engineers choose a fully-machined wheel over a cast wheel, they are only doing so to prolong the wheel's life in extreme duty-cycle OE applications where the turbo speed is constantly cycled. A typical example is a city bus, in which the turbo is frequently subjected to rapid transitions between high-load (full throttle) and low-load (idle). Compressor wheels can fail in low-cycle fatigue (LCF) in these applications, which is where fully-machined wheels offer an advantage in strength and lifetime. However, the typical aftermarket turbocharger will not be subjected to such extreme cycling.
but like they said your not likely to fall into this catagory of needing one...then again i wonder about those using two step lounch control could benefit from it.
umnitza
09-01-2015 08:06 PM
