Need some F/I guidance real quick
ok guys...motor build is almost in works.....goin with pistons rods callico bearings for the bottom end......im shootin for 350 hp...im using the emanage ultimate in open loop 3 for partial throttle tuning with a blow thru maf setup...my question is.....will my 550 injectors support the whp?....also would you recommend upgrading the fuel rail?....i know ill need a new fuel pump for that.....or can i just use the stock fuel pump and a fuel pressure regulator.......also the big question....should i keep the ultimate or upgrade to a hydra...not really wanting to go to a hydra as for the price....but if i absolutely have to i will....hrmm what else....please dont bash saying to search cause i have....i might not have went deep enough but my time isnt allowing me to...if you have anyother suggestions on what i need please feel free....im already boosted at 7psi so ive got the gauges and what not.....also.....does anyone know where a 4 gauge pod pillar is?...id love to get an egt gauge...i cant think of anything else
im assuming your looking for 350whp? What kit are you running and what size turbo? Upgrading fuel pump is a saftey net and if i was going for 400+hp i would add a fuel pump and possible rail....
550's are going to be near maxing out, if not probably maxing out so yes i would upgrade Injectors.....
What gauges do you have? Im hoping boost, wideband at least...egt is good, but look into oil pressure too, i dont trust our dummy light for the cost of rebuild haha
You will be fine with the ultimate..
550 will be a lil shy for 350 hp, 750 im sure would do it.. but a fuel return setup will be an ideal thing to do, ptuning is working on one and i recommend waiting on that.. and you dont need a hydra, but it would be so much better if you have one.. ultimate is a good piggyback but without looking at the price, ultimate is no comparison to any standalone..
and yeah let me know if you find a 4 pod a pillar!
i dont have a kit....i pieced it together....i have the revhard cast manifold...tial wastegate.....turbo size....uh....damn cant remember off the top of my head but i wont need to upgrade turbo yet......i have wideband gauge boost and oil temp....
BlingSlade
10-19-2016 12:39 AM
JonnyBigBoss
09-26-2015 08:31 PM
Subaru86
Scion FR-S ICE & Interior
09-10-2015 08:11 AM
BlingSlade
09-05-2015 08:52 AM
