need some turbo help
#43
ahhh...yeah cant forget those. does the whine go away when u push in ur clutch? if so, id lean towards the throwout bearing on the clutch. mine made a similar whine with my stock clutch. it still kinda makes a noise but not nearly as bad as before. id def say swap ur clutch out and at least resurface ur flywheel when u do it. ur gonna need a stronger clutch for boost anyway.
#45
BTW, dont put your injectors in before you do anything. the car wont make fuel trims big enough for 650's. you'll never make it down the street.
Get management. FIC, Emanage....etc. this you NEED
IMHO, id say ditch what you got, and buy a kit here in the classifieds. I picked up a ZPI stage 1 kit for 700, then bought AEM FIC and injectors for 800 NEW. Then had to piece a few small things together....oil pan, vacuum lines, etc. And im VERY pleased with the outcome. Custom kits are a NO GO if your on a budget IMO. It takes a lot of trial and error which costs money.
DO A COMPRESSION TEST and a LEAK DOWN TEST BEFORE BOOSTING. this will tell you if your in the right shape to boost. test it out, and tell us the results. this will ensure a more safer setup.
#47
Theres a guy on here named yellowhoodie. he's selling an original TT kit. get that then get an FIC on here.
and make sure you get a wideband which ever setup you go with. learn how to read it, and USE IT lol
SloTC1
08-16-2018 02:45 PM
CrowJenkins
10-09-2015 10:47 PM
