New burnout vids!!! +500HP @ 8,200rpm's SCIONGT35R's car
Originally Posted by B_Real45
Pito,
There aren't any balance shafts on that motor right?
The car sounds healthy.
I like the first vid and the last vid the best.
Any plans on going to a larger turbine?
Pito
Originally Posted by aen
Originally Posted by Mecanica_Pito
I posted a thread some time ago about oil problems on the 2AZ-FE and the help was basically none. Even companies that post here and have built high HP engines ignored it!.......
Pito
Pito
Pito
Originally Posted by TCFROEZEL
That looks hot.
i am impressed on how the phantom grip is holding.
8200 RPM rev NICEEEEEE !!
that was the best part.
Pito i will contact you cause i need some tips on my setup.
Pito
Originally Posted by toyota_scion_tc
Are you running drive by wire still? Where did you get the 82.5MM TB from?
Pito
Pito
Are you still having issues with the car dying after the cable TB? We noticed while datalogging mine on the dyno the OEM ECU was closing the TB to lower the RPM's and the car would die.
Pito
Originally Posted by ScionGT35R
^^^"if life turns its back on you ... grab its butt!"
