New DW301 Fitment for MY05+ tC!
what year is ur tc? if its an 07, ur gonna have fuel cut not matter what, unless ur using a full stand alone. i heard that 07 is the only yr that has the fuel cut issue but i personally cant back that up w facts. i know 05&06 has no fuel cut. my 07 def has a fuel cut. and supposedly 08+ has no fuel cut but like i said idk if thats true or not.
Unless the tC's are really inefficient in using fuel (doubtful since it is a Toyota engine), the DW301 should be more than enough for well over 600hp on pump gas (probably closer to 700).
The Walbro should be able to get you close to or over 500hp pretty easily.
I'd love to see you guys running DW pumps. ...but if you have a Walbro that's working, I'd feel bad for telling you to take out a running pump. ...unless, the noise from the Wally is annoying. :D
I was able to get in the mid 400's on E85 with a single DW301. If I had bigger injectors (and consequently able to run lower fuel pressure) I prob couldve hit 500whp on a single DW301 on E85. Pump gas is another story - I really cant see the reason for a dual pump setup. I have dual DW301's and make 500+ with fairly high fuel pressure (60-65 psi base) on E85 with absolutely no problems. Dual DW301's should be able to get into the 700-800whp range on E85 Pump gas - 1000+whp lol
From what we've seen, the A340 flows a little more in the low pressure ranges and our DW301 flows a little more in the higher pressure ranges (70psi+).
Our pump comes with a 3-year no-fault warranty and the A340 has a 1-year.
An added bonus is our customer service. We are actively involved in this community and easy to get a hold of if you ever have questions.
gqdabien
07-22-2015 10:30 PM
cquencebrakes
06-23-2015 09:42 PM
