New Engine Management (long time coming....)
#181
Ok. I have our local tester's car for the next 2-3 weeks. I did a little more street tuning on it last night. We run her to 6900 RPMS with a new top speed of 135mph. She is tuned to 11.5:1 AFR with some fairly aggressive ignition timing. I will have some more updates soon!
#182
If so godbless the 6900 rpms.. i reved mine to 6400 and i was scarred.. but i noticed 0 problems with any bearings or in the head!
When you say aggresive timing at how many pounds and how much timing?
#183
Stock motor, 5 PSI right now, retune soon as the boost controller comes in that the customer ordered.
#185
man i want this unit bad... i have the AEM EMS from Dezod and it is awsome. But, there are some draw back for me... like passing inspection and the EMS doesnt like the cold. im hoping with this unit i can cure some of the problems i have been having.
#186
there are a lot of people waiting on this - now that dezod sees there are people with extreme interest they will work faster (hehe sorry guys but thats always true). I ran my compression test so im ready whenever they are.
#187
Anyway, to answer some of these questions that have arisen in this thread. If, for example all you want to do is have different maps for different boost levels, that's fairly easy with this unit! Because this system uses the MAF, you can run 10 different boost levels on this one map because it's all based off relative cylinder pressure and metered air. Same theory applies to a pressure sensor equipped GReddy E-mangle for that matter. I have plenty of cars with 2 and 3 boost levels on one map with the e-manage or FIC.
#188
Sooooo... basically, XB2 owners are SOL unless we want to cut the PnP connectors off the EMU and figure out how to hardwire it into our ECU. That's okay, the AEM FIC is cheap and does a great job.
#189
Originally Posted by jwaggz82
so your saying the unit with the same tune will be ok to run at the stock 8lb's, 10lb's, or whatever? But if you are looking to change engine components you would have to get returned and then you can alter the boost accordingly? Or am I not following?
Any change in engine components that would alter VE or air delivery of the engine (cams, intake manifold, larger turbo, pistons etc) you will want to retune.
#191
^ sounds like 10lbs of boost is what i will run then - what are your views on boost management? What do you use on your cars?
#194
It's kind of a pain to set up properly, it does not have half the features of the other units, and the features it does have like scramble boost, don't work properly.
But if all you want is 2 boost setting at the push of a button, and the ability to recal your peak boost from a controller that is also your boost gauge, then it's fine.
#197
in terms of an end user - what is making this a better alternative for a user instead of using the aem/eman
#198
You said it had boost control. Any way of limiting boost, Via Gear or speed etc.
So in first you wont spin. Im asking this for higher powered cars lol. Something like they have on the MS3's. Id be kinda neat.
#200
Originally Posted by crush02342002
whats up phail...hows it hanging
The only time that gets a little tricky is when you have a map for pump gas and a map for race gas. Because the ignition tables and fuel tables may be so much more different, that can be the only time I see the need to run another map all together.
