New Engine Management (long time coming....)
#161
Originally Posted by paul_dezod
In a nut shell, it uses our preprogrammed map in substitution for the stock one, and when it goes into open loop, it references off ours as well. Quite simple concept, but complex to pull off.
Sorry if I missed it but can you give a ballpark cost for the EMU and PnP harness? How about a time frame for a XB2 version? Thanks.
#162
No estimated cost yet. xB2 will be dependent on if we can get the connectors or not.
#164
Originally Posted by coryjames
boomslang got the connectors 2-3 weeks ffor the fic harness so make one for the fic make it
#165
[Yes it works inline with the stock ECU. The fuel and spark maps can be modified as needed by anyone just like on any engine management.
Thanks again.
#166
Thanks again.
#168
The unit will be designed to be plug-n-play so there will be no harness
#172
Thats the thing - i wish they could come out with two maps standard - one for maybe 8lbs and one for 12lbs. That should hit MOST of the market and be great for people with a stock engine and those with a light build.
#174
#176
#178
Originally Posted by crush02342002
Paul anychance of sharing the afr graph from the dyno. or any graph you got
#180
whats up phail...hows it hanging
Anyway, to answer some of these questions that have arisen in this thread. If, for example all you want to do is have different maps for different boost levels, that's fairly easy with this unit! Because this system uses the MAF, you can run 10 different boost levels on this one map because it's all based off relative cylinder pressure and metered air. Same theory applies to a pressure sensor equipped GReddy E-mangle for that matter. I have plenty of cars with 2 and 3 boost levels on one map with the e-manage or FIC.
The only time that gets a little tricky is when you have a map for pump gas and a map for race gas. Because the ignition tables and fuel tables may be so much more different, that can be the only time I see the need to run another map all together.
