new engine problem TRD supercharged
Old 10-18-2006, 09:57 PM
  #41
PghtC's Avatar
yeah, poopy bearings again...
PghtC is offline
Old 10-18-2006, 10:06 PM
  #42
tc2nut4's Avatar
Originally Posted by zer0
Originally Posted by soros151
but would be some solutions?
Toyota admitting there was a bad batch of bearings.
Toyota admit something was wrong ????
tc2nut4 is offline
Old 10-19-2006, 09:08 PM
  #43
kocho333's Avatar
lol ok guys futher update, i just checked out the car today, seems they ripped apart the enire block and found that every bearing throughout was shot, all over the crank the rods everything looks like it was put in an incinerary, burnt to crisp and deep fried. everyone at the dealer is accusing me of missing a shift and over revving, anyone who knows me knows that i know how to drive my sh*t, and am not stupid, so thats out of the question....an idea that i thought of that could be a possibility was that i was running an underdriven crank pulley for the most part of the engines N/A life, and was drivin hard....so im thinking that that had something to factor in and with the newly added pressure, it couldnt take it after a while...ive only had the S/C for not even 5K miles.
anyway so they called the regional service dude guy person and he took another look and now authorized a new short block. so i went to check it out today, and damn it looks prettylol,, and as a precausion, i am not putting back the lite crank pulley, i think pushin the 9.5lb is good enough for me.lol
kocho333 is offline
Old 10-19-2006, 09:44 PM
  #44
Garage1217's Avatar
An underdrive or aftermarket crank pulley will def not cause what you are speaking of, however low to no oil pressure with the engine running at RPM will cause exactly what you decribe. Also missing a shift will definitly NOT cause what you describe. Missing hard shift usually results in more visual damage to underbuilt engines... such as rods sticking out the block... not every bearing burnt *LOL*
Garage1217 is offline
Old 10-19-2006, 10:25 PM
  #45
soros151's Avatar
well thats toyota for u, always looking how to egt out of working on you warranty.
soros151 is offline
Old 10-19-2006, 11:17 PM
  #46
zer0's Avatar
That makes 2 of the same scenerio. Both had a lightweight crank pulley with Supercharger. Interesting data.
zer0 is offline
Old 10-20-2006, 12:50 AM
  #47
soros151's Avatar
True, they should account this in the "Pulley Owners Stand Up" thread, in the Drivetrain section.
soros151 is offline
Old 10-20-2006, 12:58 AM
  #48
Garage1217's Avatar
Not related to a pulley, I know what this failure is, which is why toyota is forking over to have it fixed. They know this failure is not caused by a pulley or they would have pulled that card out of the bag right off.
Old 10-20-2006, 02:37 AM
  #49
tc2nut4's Avatar
funny... they pulled any and every card they had on me lol.... maybe even a few jokers
tc2nut4 is offline
Old 10-20-2006, 02:47 AM
  #50
zer0's Avatar
yea, they even had an uno deck in there as well... draw 2.. as in $2000 to get your car back on the road!!!!!!!!!!
zer0 is offline
Old 10-20-2006, 02:49 AM
  #51
jwaggz82's Avatar
so whats the failure caused by?
jwaggz82 is offline
Old 10-20-2006, 02:59 AM
  #52
tc2nut4's Avatar
yeahhhh.... funny what happens when they bother to actually take the motor apart
tc2nut4 is offline
Old 10-20-2006, 03:06 AM
  #53
tc2nut4's Avatar
for the last time, bearing clarances...
The bearing sizes were slightly off so they wore away, when the bearings wore away.
Then almost all his bearing shavings made it into the oil pump and caused it to seize therefore not pumping any oil whatsoever causing things to go downhill...FAST...
This accounts for his oil levels to be fine as he stated and this is what I believed to have happened in my motor but Toyota blames it on my boost pulley, funny they don't pull out the UNO deck on him
tc2nut4 is offline
Old 10-20-2006, 03:07 AM
  #54
jwaggz82's Avatar
^ jeze - i just picked up an oil pressure gauge - cant wait to get that hooked up
jwaggz82 is offline
Old 10-20-2006, 03:13 AM
  #55
tc2nut4's Avatar
yeah... i was a fool to be running FI without one... hopefully you never need it though
tc2nut4 is offline
Old 10-21-2006, 04:02 AM
  #56
kikcaffine's Avatar
So I presume the N/A 05 tCs are having this issue also?
kikcaffine is offline
Old 10-21-2006, 04:08 AM
  #57
soros151's Avatar
Maybe, I haven't seen SOOO many people having this problem. Maybe someone can chime in here and tell us how many cases have happened that they know of.
soros151 is offline
Old 10-21-2006, 04:46 AM
  #58
tc2nut4's Avatar
7 that i KNOW of... countless more that don't post on this site or happened before I started documenting them to give to my lawer
tc2nut4 is offline
Old 10-21-2006, 05:28 AM
  #59
soros151's Avatar
hum... I see. All of them 05?
soros151 is offline
Old 10-21-2006, 05:36 AM
  #60
tc2nut4's Avatar
yes.... early to mid 05s
tc2nut4 is offline
Quick Reply: new engine problem TRD supercharged
