New H-Beam connecting rods courtesy of Dezod Motorsports
Old 08-22-2007, 06:06 PM
  #41
cessblood's Avatar
watching
cessblood is offline
Old 08-22-2007, 08:24 PM
  #42
etsnet's Avatar
Can't wait!
etsnet is offline
Old 08-22-2007, 08:26 PM
  #43
Scionetics
KAD
paul_dezod's Avatar
Originally Posted by etsnet
Can't wait!
You will see yours next week Estnet. I am still waiting on those damn 750s to arrive.
HGs will be here tomorrow!!! Yahooooooooooo!!!!!!!!!!!!!!!!!!!!!
paul_dezod is offline
Old 08-23-2007, 01:30 AM
  #44
deathbyc4's Avatar
is block notching required??
deathbyc4 is offline
Old 08-23-2007, 01:37 AM
  #45
etsnet's Avatar
Originally Posted by paul_dezod
Originally Posted by equinox2355
Originally Posted by RSracer
Will these rods require notching of the block to fit?
Paul, I haven't seen a response to this yet, and I am wondering the same thing.
Missed that. Sorry.
These will more than likely require a small degree of knotching.
etsnet is offline
Old 08-23-2007, 04:14 AM
  #46
borderguy881's Avatar
if i plan to do a na build with 11.1 compression pistons with maybe 100 shot...do i need to upgrade rods?
borderguy881 is offline
Old 08-23-2007, 08:25 AM
  #47
TCFROEZEL's Avatar
Hey Paul . the Rods look nice. but do you have an Estimate Horsepower that they can Handle ?
HP range maybe ? Cause i will tell you the truth the price is VERY VERY tempting.
Paul i've just mailed you.
TCFROEZEL is offline
Old 08-23-2007, 11:20 AM
  #48
jwaggz82's Avatar
i would - crack your rod and the engine is comming out again
jwaggz82 is offline
Old 08-23-2007, 03:50 PM
  #49
Scionetics
KAD
paul_dezod's Avatar
Well the problem with connecting rods is that it is tough to put a power rating on due to so many external factors. So this is the best response right from the chief engineer at K1 who worked with us on getting these made:
Horsepower Ratings – It is nearly impossible to put a power rating on a connecting rod. Power is produced from the expanding gasses in the combustion chamber pushing down on the piston which in turn pushes down on the connecting rods. While there are certain situations which could lead to failed rods due to compressive loads, rods generally don't fail because of power loads. If rods broke due to power, they would experience severe bending to the point of permanent deformation prior to breaking. When you see a broken connecting rod where there is no seizure of the bearing or failure of the piston/pin/cylinder wall, look closely and you will see that the rod was actually pulled in two. This high tension pulling load on the rod takes place at TDC on the exhaust stroke and is caused by the piston trying to continue up the cylinder walls and through the cylinder head and the crankshaft trying to pull it back down. The heavier the piston, longer the stroke and the higher the RPM, the more pulling load is placed on the rod. When you look at a dyno sheet, you will see that as the RPM is taken past peak power the power falls off. However, most of us has seen engines that have had rods break when over revved. If power broke rods, they would never break due to being over revved.
Old 08-24-2007, 12:47 AM
  #50
TCFROEZEL's Avatar
Nice, did u get my mail PAUL ?
thx for the explanation.
Old 08-24-2007, 02:46 PM
  #51
Scionetics
KAD
paul_dezod's Avatar
Might have. I get about 200/day on my side alone. Let alone the company.
Old 08-24-2007, 09:09 PM
  #52
TCFROEZEL's Avatar
UHMN... well maybe you might give it a look.
It's about pistons from a company.
Old 09-03-2007, 01:50 AM
  #53
etsnet's Avatar
I got mine people, have you ordered yours?
etsnet is offline
Old 09-03-2007, 04:19 AM
  #54
FireStorm's Avatar
+1 For etsnet
FireStorm is offline
Old 09-03-2007, 04:25 AM
  #55
FireStorm's Avatar
Not to get off topic but....
Deatsch Werks Plug-N-Play 550cc Injectors-Scion tC 05
Those are simple just take out old ones and replace the stockies??
Old 09-03-2007, 07:30 AM
  #56
etsnet's Avatar
Yes. Go with the 750s if you're going built.
etsnet is offline
Old 09-03-2007, 04:44 PM
  #57
TCFROEZEL's Avatar
Looking Good. when is your rebuilding start etsnet ?
Old 09-03-2007, 08:12 PM
  #58
etsnet's Avatar
Hopefully in a few days starting with the sleeve and then I have to send the internals to the assemblers. I hope to have the motor back by the end of September and have it in and tuned by mid October.
etsnet is offline
Old 09-03-2007, 10:07 PM
  #59
TCFROEZEL's Avatar
NICEEEEEE ... very nice. what EMS are you going with ?
Old 09-03-2007, 10:14 PM
  #60
etsnet's Avatar
Emanage basic for now. Hopefully I'll be able to get the AEM standalone in the spring.
etsnet is offline
Quick Reply: New H-Beam connecting rods courtesy of Dezod Motorsports
