New H-Beam connecting rods courtesy of Dezod Motorsports
Old 09-03-2007, 10:42 PM
  #61
amdforever's Avatar
Noob question, I google image searched and can't find the difference. What is the difference between and "a" and "h"? Performance, longevity, the abililty to handle more stress?
amdforever is offline
Old 09-03-2007, 11:03 PM
  #62
TCFROEZEL's Avatar
yea man definatly go with a full standalone AEM would be great since it's plug and play. you could squeezedefinatly some horses with the e-manage.
like i understand H-beam can handle more stress then the A- beam. But i am not sure how much more!
TCFROEZEL is offline
Old 09-04-2007, 07:47 AM
  #63
turbogsxr750's Avatar
an a beam rod has more of a taper to it going from the main journal to the pin journal it gets some what smaller. An H beam rod stays the same width all the way to the top.
http://images.google.com/images?hl=e...beam+rod&gbv=2
The first picture is an A beam. the second picture is an H beam. The fifth picture is an I beam rod.
turbogsxr750 is offline
Old 09-04-2007, 01:47 PM
  #64
Scionetics
KAD
paul_dezod's Avatar
Thanks turbogsxr759 for answering.
Yes these are back in stock as we have been blowing through these sets...
paul_dezod is offline
Old 09-04-2007, 04:24 PM
  #65
Scionetics
KAD
paul_dezod's Avatar
FYI thanks to the overwhelming response on these rods. We are down to 5 sets off of the 1st production run. So those who do not want to wait......order up!
Old 09-05-2007, 03:43 PM
  #66
krazylowgsx's Avatar
i am seriously thinking about ordering a set of these. these would be perfect for my 500hp build, and i'll just put my A beam rods in my wifes car.. then all we'll need is pistons for her car, and a boos controller =)
krazylowgsx is offline
Old 09-05-2007, 03:58 PM
  #67
Scionetics
KAD
paul_dezod's Avatar
In stock for the rods. We have you covered. Call or order online.
Old 09-05-2007, 06:08 PM
  #68
Mr_Meaty's Avatar
How much normally would you expect a shop to charge for installing these?
do you think this is all that is neccessary to push 450hp? Or would pistons and bearings be neccessary as well?
Mr_Meaty is offline
Old 09-05-2007, 10:10 PM
  #69
etsnet's Avatar
If you read a few post back it explains that the rating can't be put to a number but you should be fine for 450whp. I would also get the pistons and bearings are good to replace while you're at it.
As for the cost to install, someone I know just called locally to a good shop and they said it would be about $1500 with install and tune but said it maybe a high quote that he has to talk to the tuner.
etsnet is offline
Old 09-05-2007, 10:43 PM
  #70
BMTWhiteScionTc's Avatar
Sup PAUL! Its Jake in AZ. Joe did my turbo and it is awesome. Thanks for every thing. Im planning on ordering Pistons and Rods eventually so I can run more Boost. How much for me to do it with my set up. Also how much does it usually cost to get them installed somewhere. Dezod is the Best out there. My turbo kit is Bad A$$! lol
BMTWhiteScionTc is offline
Old 09-05-2007, 11:00 PM
  #71
t_urbo_C_harged's Avatar
First... may be a noob question, may not, but could you show me or direct me towards some information on how to notch the block. I can picture it in my mind (basically making room for the connecting rod by removing/notching/cutting some of the lower sleeve of the cylinder but I was just wondering if there is a fine art in it or is it just a mark and cut sort of thing?? thanks for any info, greatly appreciated! The rod's look great, probably will add these to the list...
t_urbo_C_harged is offline
Old 09-06-2007, 01:59 PM
  #72
Scionetics
KAD
paul_dezod's Avatar
Hey Jake....Welcome to the dark side.
Anyway, these rods are bottomed out on cost...so the $479 for the set is your cost. Pistons have been a hot commodity and $599 there.
Enjoy that kit!
Old 09-06-2007, 02:00 PM
  #73
Scionetics
KAD
paul_dezod's Avatar
For liability reasons of the company, I can not. Please consult an engine builder.
Old 09-06-2007, 06:25 PM
  #74
This is something you can do yourself but i wouldnt recommend it. You have to make sure you dont go to deep or to shallow. The rod needs to have .050 clearance from the block at any point. Also if you do this yourself you take the chance of slipping and hitting the cylinder wall and messing up you block. It would be your best bet to take your block to someone (that knows what they are doing) that has a verticle end mill and let them do it.
Old 09-06-2007, 10:17 PM
  #75
thanks for the info!
Old 09-07-2007, 02:00 PM
  #76
Scionetics
KAD
paul_dezod's Avatar
Still in stock!!!!
Old 09-07-2007, 10:04 PM
  #77
Enrique_Dezod's Avatar
Bump fo yo mama!
Enrique_Dezod is offline
Old 09-10-2007, 02:09 PM
  #78
Scionetics
KAD
paul_dezod's Avatar
Werd. Let's move these!!!!
Old 09-14-2007, 01:36 PM
  #79
Bumpy Bump
Old 09-14-2007, 02:01 PM
  #80
Enrique9876's Avatar
great buy! i would ... but after talking with the gentlemen of dezod... im probably going to need a new tubine housing and manifold .... sstill the rods are DIRT cheap.
if money grew on trees, id be a farmer.
Enrique9876 is offline
Quick Reply: New H-Beam connecting rods courtesy of Dezod Motorsports
