New Scion Tc Turbo kit.......Cast Turbo Manifold!
#85
ok, so say i took anyone else's turbo kit...used race gas and no ecm piggy back or tuning..would i get the same hp numbers?
if so, i don't understand what is so special here.
except the fact that i might have a kit that shoots out major power, but has no daily dependibility? just trying to get an education here and i still don't see answers...
and the whole "ancient chinese secret" isn't going to cut it if you have plans to sell this thing. patents protect you, not secrets.
plus trd claims a full warranty up to the 5 yr powertrain with their s/c. unless you can provide guarantees like that, the super secret r&d means very little to a consumer.
#86
I could believe that the stock ECM with properly matched injectors could provide proper fuel requirements with the proper designing. But I think the easiest way to solve this question is to post a dyno run with A/F ratio. That could lay some worries to rest
#90
As for the instant hp w/ race gas thing, you'd need to learn to read a little closer (and this goes to Treadstone: you guys might want to clarify that part a little more because it sounds like adding race gas will magically boost your power.) It says that with race gas, you can get up to 350 hp because you can safely up the boost. .
I bolded and italicised because it seems like a lot of people aren't getting that point.
Edited because it was flip flopped!
#91
Thanks for the clarification on this matter, as well as the R&D fuel manage discussion, you are exactly right! Piggy back ECU's like blue box greddy are sometimes like a bandade, or just another selling point to make money!
350whp was with race gass,
I think it was close to 300 at the wheels on 93 octane
#93
Originally Posted by kungpaosamuraiii
The "secret" is only the specific size of the turbo and the R&D put into the kit to avoid using engine management. As far as I know, with enough R&D put into other things like the MAF, you could thereoetically get away without a piggy back. The tC's ECU is pretty damn smart and relatives of it (other Toyotas) have a few times outsmarted GReddy blue boxes. And besides, tuning the MAF does the same thing as tuning the Emanage. You fool the computer into thinking one thing and get it to react in a certain way that's beneficial. One way of doing this is to put a baffle before the MAF to make it see less air going in which'll put more fuel into the mix. Unfortunately, the little smarty behind your glove box is going to relearn the conditions and readjust. To deal with that, you gotta mess with the rest of the sensors so that they see what they want to see.
Less air metered will mean less fuel supplied? Somehow restricting airflow through the MAF will not supply more fuel, it just won't. That would mean the ecu would lean out the motor in the upper rpm range, which it doesn't do.
#94
First of all it's good to finally join the SCIONLIFE forums . I've been reading post in this tread for awhile now but just recently decided to join. I just wanted to say it's good to hear to finally see a turbo kit that will fit the 07.
#95
thanks for the expanded info kungpao. so let me ask you...is it better to have mechanical parts that fool the ecu, an ecu piggyback, or a full reflash? from an ecu learning and parts longevity standpoint.
#96
Treadstone could you just explain a little more in depth the Velocity Stack type MAF adapter. What does this do in terms of helping the A/f? And explain what it does to the MAF sensor.
Your kit looks great, i would like to know alittle more about the adapter.
#98
As far as what's the best way to fool an ECU? ATM, I'd go for Unichip. It doesn't bother fooling the ECU; rather, it just messes with the signals the ECU sends out. However, Unichips have been known to fail before so... who knows. I would rather use electronics to tune since you have direct control over what's happening. Mechanical tuning like this... it sounds iffy to me. If you can keep on fooling all the sensors than it should work just fine but Toyota has some GOOD coders.
