Nitrous Express... need some direction
Unique Scionikz
Hey everyone... I just aquired a partial sponsorship from Nitrous Express but I need help on deciding which of their many kits I should use for my tC.
I was thinking maybe their Import EFI All vehicle applications:
http://www.nitrousexpress.com/Pages/ImportStage1.htm
or thier Hitman EFI series:
http://www.nitrousexpress.com/Pages/20001.htm
Here's a page with all their Import applications:
http://www.nitrousexpress.com/Pages/Importmain.htm
WeDriveScions, I know you have experience with the ZEX kit so maybe you might be able to give me some input on which route to go. I'm shooting for a 50 shot and maybe a 5 or 10 lb bottle.
Any input is appreciated.
Please no "naaaaaaaaaaaaaawwwwssss" bashing or flaming .
hey i'm all about it... i was kicking around the idea of getting the hitman efi series but couldn't cuz i had to buy some winter tires...
p.s. blizzaks are the ISH
back on topic: I'd go with the Hitman EFI, bit more of a user friendly kit IMO... i also like the push button activation feature so you can get one of those spiffy shift ***** with the button it that way you're not spraying between shifts (common with steering wheel buttons) and dont blow your motor to smitherines
Pick up part # 18959 (Window Switch) and # 15961 (TPS Sensor Switch) as well
I strongly suggest not going with the sole route of running a push button, like in the movies, as the above two switches really protect you and your engine from running the N2O at too low of a RPM, or Too high of an RPM (above limiter), as well as running at anything other than WOT, which is the only way to go. Any of the guys I see at the track don't just run a button on their cars anymore.
Plan on killing your stock fuel line in the engine and using the two ends of it to allow a better race fuel line to run in it's place, so you can tap that more effectively.... (the stock fuel line in the engine is plastic and near impossible to tap)
Hope that gets you on the right road... picking up a Wideband couldn't hurt as well, so you know you're jetted perfectly and not leaning out...
-WDS
Unique Scionikz
Yup... haha Tim I wish u'd be here to help me out when I get it. I'm sure Erik (The_Instigator) and I could tackle this down tho... i hope.
It looks like i'm leaning towards the Hitman EFI series. Would it hurt if I ran w/out the Window Switch & TPS Sensor Switch in the beginning and add them on when more funds arrise?
Unique Scionikz
Re: nxexpress
Originally Posted by Freddy
Get the direct port efi kit part # pn80004efi. It's got the piranha nozzles and is direct port wet system will handle up to a 500 shot. This is the kit Iam running on my x/b 75 shot.
http://www.nitrousexpress.com/Pages/80004EFI.htm
Would it be safe on the tC? I'm not planning on doing a 75 shot.... a nice simple 50 shot would do the trick.
buy these
That's the one, you can run a 50 shot on x/b so the tc would handle 75 shot. Get the maxmizer 2 progressive controller and gen x-2 kit . You might think about upgrading your injectors and fuel pump and fuel lines and add a return fuel line and adjustable fpr then you will be done.
Unique Scionikz
Well I was talking with Josh @ NX and unfortunately the Hitman EFI does not apply to the sponsorship. So now its a battle between the Import EFI All App. kit or the 4 Cylinder EFI Piranha kit that Freddy has.
Decisions.... Decisions.
Import EFI.... Simple and effective... no need to get too complicated with jetting the direct port... either way will be good, just the standard wet will be SOOO much easier to install.
Sorry Mike
But you can do a direct port system. I had my nozzles taped right into the head. This way you get a wet direct port and the nozzles are hidden. Someone on this site epoxy the nozzles on a x/b plastic manifold I don't think it would hold plus everyone would know you are running nitrous.
Freddy
Freddy
BlingSlade
10-19-2016 12:39 AM
umnitza
09-01-2015 08:06 PM
