No O2 sensor readings from ODB-II scanner
Old 11-29-2006 | 10:08 PM
Streeter's Avatar
Default No O2 sensor readings from ODB-II scanner
Basically what it says - I'm using ProScan from myscantool.com. There is no voltage monitoring at all - basically it acts like it's not supported. I have the ElmScan 5 hardware (supports all protocols). Is it possible the software just doesn't support WRAF (wide range air/fuel aka wideband O2)? Does anyone use any other software that does read it?
EDIT: I should probably mention that it doesn't read from EITHER O2 sensor - not the wideband, and not the narrowband.
Old 11-29-2006 | 11:13 PM
ERIC-TC's Avatar
I use Autotap and it supports the narrow-band 02 sensor. I get the actual voltage I've got a fomula in excel that converts it back to A/F -but the narrowband sensor is only accurate near the 14.7 A/F mark.
Old 11-30-2006 | 07:32 AM
OuterHeaven's Avatar
The wideband part of the Toyota OBD-II is not standard and no regular OBDII scanner will work unless it has the special software that will interface with the Toyota ECU to read the non-standard sensor data. I personally have Proscan also and I really use it to monitor ignition and fuel trims. If you want to tune using a wideband I do no recommend an OBDII scan tool because the frame rate is very slow. Just get a wideband.
Old 11-30-2006 | 03:38 PM
Streeter's Avatar
Sounds like it's as good as the software... AutoEnginuity(.com) looks pretty good, and you can buy the Toyota-specific addon to get those codes.
http://www.autoenginuity.com/Toyota_...or-list-1.html
This suggests that it actually works - they say 1ms refresh rates too. That's pretty spendy, when you add it all up though. (About as much as a wideband...)
nightfox915
04-17-2015 08:06 PM
daniinpitt
04-04-2015 09:07 PM
tha17
02-05-2015 01:56 PM
hotroddelux
12-04-2014 12:33 AM
