No Respect for the tC
#147
Originally Posted by GReddy_tC
All I need to hit 330 is 10 lbs. so I figure around 11-12 to hit my 350hp goal..
Mane you didnt know.. Travis is my scion daddy. But, we don't kiss like wayne and baby... lol
I think I'm the "God Father" of the Scions where we are from Vinny.
#150
@ travis..
I'm not saying p-tuning or any other tC is SLOW on a track... im saying... there are limitations to the FWD platform that the tC is on both handling wise and putting the power down to the ground.
again... p-tunings tC might be CLOSE to a factory tC but its not exactly DD material either.
I spent less on my subie than I would have building my tC and I have the confidence that at my current setup I can beat on the car all day and not worry about the drivetrain, motor, or aftermarket piggyback ecu's
in order to build the same thing out of a tC i would have had to
1. Build the motor ( lower compression) for high boost ** my subie has a 8.2 compresson ratio**
2.Turbocharge the car
3. Get a aftermarket engine management system and get it tuned
4. Build the suspension to handle the power
5. Build the transmission to squash any worry of it failing under repeated track day
I don't think you can argue the fact that a factory turbocharged AWD/RWD car that is capable of being a DD is the best option for someone who needs to be competitive and then drive home from the track
Again, im not hating on the scion tC at all I loved mine when I had it. I just needed a different platform that would help me do everything I wanted to do. I never really ment to jack this thread and turn it into this... I was just providing my .02
#151
Because of the flow charactrisctics of this turbo.. Im going off of what paul at Dezod told me. And, he's the guru. So, I trust his word.. Its a 62mm turbo. A lil bigger than all the 10psi 300hp turbos we all usually run..
#152
Hey "SoGone", not to be a dick, but id think again before you talk about the subie and the reliability factor.
If you didnt know, there have been PLENTY of 300+awhp subaru
Drivelines that have broken under track abuse. The first part
To usually go is the axles and transfer case.
And the same goes for the tC, after 300+whp, things get hairy...
But i wouldnt put the wrx in a class of its own when it comes to strip to street reliability...
#153
there are plenty of WRX drive trains that are broken because people are retarded and try to launch them AWD at 5k
there are plenty of them over 375whp that run fine.
how many Sti ones are broken?
i picked up an 07 for 25k and my tranny is good to 400+ whp....
so I dont see a valid point... you can pick up sti's cheap if your willing to look.... again... cost benefit...
tranny is just ONE component of the entire picture....
you cant argue that a 300whp tC is as reliable as a 300whp WRX sti or not....
on or off the track....
Im not willing to further argue this.... if you don't choose to see it so be it... im not trying to detract from this guys thread and his good kills!
#154
hmmm im not arguing about reliability of cars. I personally like subaru's. They are good looking, quick cars. But wheres the fun in buying a car that is already fast? I have less then 3k into my motor, and less than 2k into the suspension to handle it all.. and my car runs great. It is very reliable. And its pretty damn fast for a street car. I have taking on many long distance trips without any problems. I also race often with no problems. ..so why are you bashing on this guy? He'll be fine with his turbo.. 10 psi is a safe setting.
#156
Originally Posted by soGone
@ travis..
You paid MORE for the car. You might have not bought as much aftermarket parts to make it perform where you want, but you do realize you already paid for that performance up-front in the actual price of the car.
1) Wrong, don't need lower compression to make hella power. Since we are comparing this to your subie, you don't have over 400whp do you? Which is what the threshold is for the 2az before needing a build.
2) Yes, but once you turbo charge it, it will destroy your Subie
3) And you would also if you plan on going above the stock power. Even if you bought a Cobb tune, its still an aftermarket engine management solution that was tuned by someone else. Just easier to get on the car.
4) Yep, good set of coilovers
5) Tranny has been proven to take repeated track abuse, so the answer to this one is No you would not.
Adding the prices up of anything I said yes too, it still would not cost you more on a tC.
And that's all I have to say about that.
#157
