Non-Sleeved Short Blocks & Ported, Built Heads
Old 10-06-2011, 01:05 PM
Scionetics
KAD
paul_dezod's Avatar
Originally Posted by PeArLwHiTe07tC
u can push over 500+ on stock sleeves. idk how long theyll hold up, but i know quite a few ppl on here have had some good results. its also contingent to how good of a tune u have.
It's VERY contingent upon the tune, setup and fuel used.
paul_dezod is offline
Old 10-13-2011, 02:16 PM
Scionetics
KAD
paul_dezod's Avatar
Note, we also offer several head services for you as well including fully built and ported heads!
Head includes
Upgraded +1mm stainless valves
Upgraded dual wound valve springs
Titanium retainers
Upgraded seat locators
Upgraded valve seals
Upgraded valve locks
Bronze valve guides
We will also re-shim the head if you supply the cams you are going to run.
Old 10-18-2011, 03:52 PM
Scionetics
KAD
paul_dezod's Avatar
Now offering the option of balance shaft removal or retention on each block built.
Another left here today. Another will leave Friday or Monday.
Old 10-18-2011, 04:12 PM
Roller_Toaster's Avatar
Originally Posted by paul_dezod
3) The tuner is programming VVT and ignores the fact that piston to valve contact can occur and it does.
Huh, I never realized our engines were interference type.
With your head upgrade(dual valve springs), what could the 2az safely rev to?
Roller_Toaster is offline
Old 10-18-2011, 04:37 PM
Scionetics
KAD
paul_dezod's Avatar
Define safely? That's a tough question to answer truthfully and accurately. We have several customers whom run 7300 regularly. I have seen as high as 7800, but I would not recommend that to anyone.
Old 10-19-2011, 06:25 PM
Scionetics
KAD
paul_dezod's Avatar
Another two off to the machine shop!
Old 10-25-2011, 03:20 PM
Scionetics
KAD
paul_dezod's Avatar
Two more being done. An 05-06 should be leaving here in the next 1-2 days. Machine shop fell behind and we where also waiting on the OE rear main seals, but they arrived today.
tcer904
24
08-30-2015 03:13 PM
djcezile
04-23-2015 06:46 PM
tom0613
03-07-2015 05:59 PM
wiltonhall
01-28-2015 03:46 PM
Quick Reply: Non-Sleeved Short Blocks & Ported, Built Heads
