Nothin Scion Life.. or the Scion tC has seen before!!
#122
hey greg_jspec...i just went to STSTURBO.com and all there **** looks legit...i personally have never seen a rear mount kit on any car, so this is really intesting. i wonder what gains you will get from this set up compared to a normal setup...keep us posted dude and good luck
#125
sorry for caps i was just typing haha not angry..
#135
Will you entire exhaust be heat wrapped? I am curious because exhaust gasses flow with greater velocity at certain temps and since your turbo is going on the rear of the car away from everything then the EGT will be low towards the back of the car. For example if you measure EGT on a stock ECU tC in the beginning of the manifold where the sensor is suppose to be placed you will see between 1250-1600 depending on outside temps and how hard you are driving you car. If you move the EGT probe down a few feet it might show 750-1100. I am only using those numbers as an example not to be taken to be 100% correct. I have notice my car EGT at WOT 1575 plus or minus 75 degrees. If you measure you EGT at the rear of the car then I would believe you would see 500-600 (could be more depending on exhaust setup or catalytic converters). I might be wrong but due to the lower EGT's I would expect to see a 10-25% difference then a front mount turbo. Good luck and I hope everything work out like you are planning on. BTW the oil pump shown is the pic is this used as a oil scavenge pump or an oil supply pump?
NonStopTuning
01-20-2015 06:20 AM
foxSCION
13
12-03-2003 06:40 AM
scioninla
14
10-18-2003 04:46 AM
