off throttle/deep vacuum afr
Old 09-23-2008, 03:49 AM
purevision01's Avatar
Originally Posted by enjoithis
by "Deep Vac" are you referring to the engine when you are in gear and completely off the gas? Idle/ cruise vac, about -20 psi im running about 15 +/-1
when i down shift (approaching a stop) completely off throttle im at -22psi (i believe this is max on the AEM Tru boost gauge) and my AFR is "---" which is 17++
I never really questioned it.... you're making me think about it now. What would a good tuner (obviously not mine) have for the afr "Goal"
The vacuum is measured in inches... discovered when mercury was put in a tube at room temp and placed under a vacuum, the mercury would rise and measured. Anyway thought id throw that out there so I can understand.... First time reading the post I was like, how can you make any boost with you foot off the gas... lol But yours sound pretty good, about what I would have them set at.
purevision01 is offline
Old 09-23-2008, 09:24 AM
Ronin Scion
Ace83's Avatar
lol the psi thing confused me a lil too but yeah, your off throttle afrs sound like what the rest said
Ace83 is offline
Old 09-23-2008, 01:46 PM
Scionetics
KAD
paul_dezod's Avatar
Default Re: off throttle/deep vacuum afr
Originally Posted by Ace83
I have my off throttle/deep vacuum afrs at around 11s-12s, would it be better to leave it that rich or make it leaner, or what should the desired afrs on deep vac be? i noticed the car feels heavy or drones a lil louder with the afr i have
Do you not have decel fuel cut engaged or are you speaking about high idle on a cold start?
paul_dezod is offline
Old 09-23-2008, 01:47 PM
enjoithis's Avatar
"decel fuel cut" thats what its called! From my knowledge this means when decel .. no fuel?
enjoithis is offline
Old 09-23-2008, 02:03 PM
Scionetics
KAD
paul_dezod's Avatar
This means when your cruising or on any throttle at all (usually above 3% or 5%), and release the throttle and just coast either in gear or neutral, the AFRs will jump to off the charts lean to get better fuel economy.
Old 09-23-2008, 02:04 PM
Ronin Scion
Ace83's Avatar
oh yeah i forgot to check on that setting.. but im pretty sure its my fuel map.. but no im not referring to idle or start up just on decelerating after letting off throttle
Ace83 is offline
Old 09-23-2008, 02:06 PM
Thats correct but the injectors should open back up around 1000 -1300 rpm to prevent the engine from stalling. U kno the all so familiar buck the car likes to do when you try to come to a complete stop while still in gear.
I believe the factory leaves the injectors functioning for maybe a second or so after the gas is depressed to keep the rpms up in between shifts, but I believe the throttle plate may also be slightly ajar at the same time but never took the time out to check exactly whats causes this.
At what engine load percentage and rpm are you seeing the engine stumble?
Old 09-23-2008, 02:10 PM
Scionetics
KAD
paul_dezod's Avatar
Decel fuel cut, which usually occurs anywhere from 2-3 seconds after throttle being released.
Old 09-23-2008, 07:41 PM
B_Real45's Avatar
That's what my Unichip map does.. as soon as I let off throttle it goes extremely lean - then back to stoich. It runs very smoothly.
B_Real45 is offline
Old 09-23-2008, 07:43 PM
Scionetics
KAD
paul_dezod's Avatar
Uni-chip does nothing. It's programmed into the stock PCM for better fuel economy.
Ronin Scion
Ace83's Avatar
my decel cut is on, now its time to play with fuel map and enleanment coefficient.. i did notice it going smoother as i leaned it out
Ace83 is offline
Old 09-24-2008, 02:27 AM
B_Real45's Avatar
What does that mean? It does nothing to the stock ECU. It alters signals coming out of the ECU as opposed to Greddy or AEM that intercepts the signals before the ECU.
B_Real45 is offline
Old 09-24-2008, 02:32 AM
I believe paul is talkin about the decel fuel cut.
Old 09-24-2008, 02:36 AM
Ronin Scion
Ace83's Avatar
I guess what paul meant is that its our stock ecu tune that control that and not the tune that came with the unichip.. the nice thing about the piggybacks is that it allows you to retain some tune/settings that are designed for drivability and are reliable from the factory instead of figuring out to make a complete tune.
Ace83 is offline
Old 09-24-2008, 01:28 PM
Scionetics
KAD
paul_dezod's Avatar
Yes Ace, I was referring to it doing nothing with respect to DFCO. I like playing with it. You can make it as aggressive as you want, a laxed way or not on at all. They joys of a standalone are second to none.
SloTC1
08-16-2018 02:45 PM
Hydryman
02-23-2016 03:35 PM
vi3tb0i09
09-23-2015 08:32 PM
rancur3p1c
07-12-2015 07:59 PM
StylinMotors
03-12-2006 08:32 PM
Quick Reply: off throttle/deep vacuum afr
