Official Motor Build End-All Super Thread!!!
Old 09-16-2008, 12:22 AM
  #301
B_Real45's Avatar
Yes - I would step up those 550cc's just to have that extra cushion.
B_Real45 is offline
Old 09-16-2008, 12:23 AM
  #302
coryjames's Avatar
Originally Posted by java09
should i buy the one from 20tcdude? hahahaha
that kid is a tool lol
coryjames is offline
  #303
java09's Avatar
for 310 on 550's on my car id say step up to 700's cause my injector duty cycle is high.. my car needs alot of fuel! haha
java09 is offline
Old 09-16-2008, 12:24 AM
  #304
SoFloTC's Avatar
i jsut bought my rods, head studs and bearings and head gasket from him today for 750.. not a bad deal. everything was new and unused.
SoFloTC is offline
Old 09-16-2008, 12:25 AM
  #305
coryjames's Avatar
where did you talk to him lol isnt he dead
Old 09-16-2008, 12:26 AM
  #306
SoFloTC's Avatar
clubsciontc.com
hes sellin alot of crap.
SoFloTC is offline
  #307
java09's Avatar
nice deal.. i was considering it but i figured wait till i come back from iraq and buy EVERYTHING CASH!! haha then make it rain at the club and be broke it 2 days! hahahahahaha i can spend 90k that fast! bahahahaaaaa
java09 is offline
Old 09-16-2008, 12:27 AM
  #308
SoFloTC's Avatar
ur insane haha... dude everyone i know thats in the army or marines makes a crapload of cash.. im about to enlist.
SoFloTC is offline
Old 09-16-2008, 12:28 AM
  #309
coryjames's Avatar
tell you the truth why he is selling the motor is it wont make oil pressure and no one can figure it out lol and clupsciontc i think i have a acount over there lol
Old 09-16-2008, 12:29 AM
  #310
java09's Avatar
haha at a price my friend.. im in the navy.. choose the branch you join carefully.
but yeah when all is said and done 450whp and ill be happy.. then when i reach that i wont be...
java09 is offline
Old 09-16-2008, 12:33 AM
  #311
SoFloTC's Avatar
thats exactly how it is man.. u will always want more.. soon ull have a 800 hp tc after u blow 40 grand
SoFloTC is offline
Old 09-16-2008, 12:39 AM
  #312
java09's Avatar
hahaha 800whp tc here i come... hahhaa
java09 is offline
Old 09-16-2008, 01:33 AM
  #313
purevision01's Avatar
would u guys suggest me move up to 700cc injectors from the 550 if im running 16 psi trying to get 350 whp?
550cc will be fine if building a return line setup as they will flow enought for 350hp... but if you want to guarantee that you will have enough fuel, go for it... Deascht has a set of of drop in 700's for about 450 i believe.
purevision01 is offline
Old 09-16-2008, 01:40 AM
  #314
our axels are good for like 500 hp or something even higher. i believe
That is incorrect. I believe it's 300 and even then you have to be careful but if you don't launch hard you'll be fine.
BTW, K1 rods will not need notching.
It is not hp that snaps axles its torque... And the stock axles will handle 500 hp depending on the amount of torque the car makes and how crazy the driver is. There are plenty of cars on the forum and that I have built producing in excess of 300whp and have had not issues or signs of axle failure.
Old 09-16-2008, 01:44 AM
  #315
coryjames's Avatar
lol banging gears with a high hp number will do it every time learn to match up gears and drive gentle they will hold alot
Old 09-16-2008, 01:59 AM
  #316
java09's Avatar
yeah im gentle on my axels but then again i only have 272 wtq..
java09 is offline
Old 09-16-2008, 03:29 AM
  #317
SoFloTC's Avatar
lawl
SoFloTC is offline
Old 09-16-2008, 11:33 PM
  #318
etsnet's Avatar
So if you built enough tCs then you'd know the HP and TQ are pretty close to the same.
I'm also not talking about everyday driving I'm talking about on the track where power is meant to be used. If you plan to race it at all and launch it the way a race car should be then plan on replacing the axles a few times unless you get built ones. It really all depends on what you will do with the power you have but I still stand by that the stock axles hold 300hp.
etsnet is offline
Old 09-17-2008, 01:59 AM
  #319
You have a strong conviction with this axle business... The only explaination is you mustve broke one... But there are plenty of tcs out there that did not have an issue yet... Never the less there really is no point in buyin new axles unless the current axles fail... Personally, myself along with my customers have had no issues with the stock axles or trannies...
U are correct... If you pound the drive train long enough you are bound to brake something but I seriously doubt it will be the axles on an auto tc... Autos have less drive train shock on the launch if brake boosted and unless the car has a seriously heavy duty shift kit installed I doubt the shifts will do much damage...
IMO the stock engine mounts would go before the axles... And if you have any buddies with 400+ hp hondas or acuras, check to see what axles they are using... Most are stock, and if you compare a GSR axle to a tC axle, you will find the tC axle is visibly larger, both the shaft diameter and the CV joint.
As far as HP vs Tq output... Stock tc's have very close hp tq ratios, but turbo applications will have a much different ratio depending on the size of the turbo and what kind of head work is done...
I also build the tC's to have slightly lower torque but highier hp output on street apps because the car has poor weight transfer characteristics, so launchin the car on anything but a full slick will result in the car spinning wildly thru the gears. Reducing the torque will allow the car to hook better and return a better 60' time.
These are my personal beliefs, not to say that they are the end all to building all cars... I am only stating combination that worked best for my car and my customers cars in this region of the country.
Old 09-17-2008, 01:01 PM
  #320
etsnet's Avatar
Never broke an axle. I have been on these forums for ever and a day and know what others have been through. I do have to say you are right about the auto that something else would probably fail before the the axles like the tranny.
etsnet is offline
