Official Motor Build End-All Super Thread!!!
Old 09-17-2008, 01:20 PM
  #321
SoFloTC's Avatar
In curiousity because the shop i had send out my tranny the owner who i talk to alot about cars said even with 16 psi i wont get past 320 whp.. i looked at him and thought he was an idiot but what kind of numbers do u think i would be putting down at 16 psi with the auto on meth? I ordered the tranny stall saying i wanted to be near 350whp.
note i put 242 whp on 6 psi on dynojet numbers.
SoFloTC is offline
Old 09-17-2008, 02:42 PM
  #322
SoFloTC's Avatar
ok so i had ordered cp pistons 9.1 88.5 mm bore but japtrix is telling me that i should of gotten 20 over pistons cuz if we use stock bore since my car has 50k miles on it they might not sit well or something? anyone? if i need to get 20 over pistons what does that mean.
Also they said i should get a new oil and water pump because of my mileage? would u agree? is this the same oil pump that level ten says they upgrade with the transmission? or seperate. i have alot to learn as i see lol.
SoFloTC is offline
Old 09-17-2008, 03:36 PM
  #323
Racersky's Avatar
Depends on turbo size......what the efficiency level of the turbo is. Can't always go by 16psi to this and that.
Racersky is offline
Old 09-17-2008, 04:24 PM
  #324
brett561tc's Avatar
it means that over time your cylinder walls will become scratched. when you put in new pistons, the cylinder walls will need to be bored out slightly in order to remove the scratches and make everything smooth again. by doing this, it makes the bore size slightly larger, and stock bore size pistons will not be large enough. this can cause massive blow by. one way to fix this is to get pistons that are .020mm larger, or to get new aftermarket sleeves bored to stock size.
brett561tc is offline
Old 09-17-2008, 04:26 PM
  #325
SoFloTC's Avatar
____ i already ordered my 88.5 pistons .. now im gonna have to send them back hopefully they take them back.
so i should order 88.7 bore? or what?
SoFloTC is offline
Old 09-17-2008, 04:30 PM
  #326
brett561tc's Avatar
poop i already ordered my 88.5 pistons .. now im gonna have to send them back hopefully they take them back.
i would go with a 90mm bore, since thats the only other size head gasket that cometic makes.
Old 09-17-2008, 04:34 PM
  #327
SoFloTC's Avatar
they make 89 and 92 i thought.
SoFloTC is offline
Old 09-17-2008, 04:37 PM
  #328
brett561tc's Avatar
http://www.raceeng.com/c-4038-gaskets.aspx
Old 09-17-2008, 04:38 PM
  #329
Mecanica_Pito's Avatar
They are talking about Engine Oil Pump and not about Transmission Oil pump! And Yes at 50k miles you should replace them both.
Pito
Mecanica_Pito is offline
  #330
SoFloTC's Avatar
uh on cometics site they say 89 and 92
so i should get 90 bore then?
SoFloTC is offline
Old 09-17-2008, 04:41 PM
  #331
SoFloTC's Avatar
ok.. im freakin out about this i bought the CP pistons off ebay and the shop i got them from doesnt respond.. i hope they didnt ship them out yet.
SoFloTC is offline
Old 09-17-2008, 04:43 PM
  #332
brett561tc's Avatar
EBAY??!!! for how much?
Old 09-17-2008, 04:45 PM
  #333
0.020" over bore is equal to 0.5mm. So that makes the piston an 89mm not 88.7mm!
I honestly think you should do three things:
1- Search more in the Forced Induction Area before asking
2- Go and ask all these questions to the people building your engine because they are going to do things their way and not what people in ScionLife say!
3- Start a thread to post the questions regarding your Auto tranny and the power level you want it to hold
Pito
  #334
SoFloTC's Avatar
592 shipped with pins,locks and rings..
SoFloTC is offline
Old 09-17-2008, 04:50 PM
  #335
brett561tc's Avatar
you could have bought them locally from race engineering here in lake worth for $500. and you wouldnt have to worry about being robed over the internet.
Old 09-17-2008, 04:53 PM
  #336
SoFloTC's Avatar
shame..
SoFloTC is offline
Old 09-17-2008, 05:26 PM
  #337
purevision01's Avatar
Personally, I wait to take the head off the block to see what is needed... But in the builds I have done, only one car had a scuffed cylinder wall because of a bent rod... All the others looked just as good as they would have from the factory, so you might be ok... But the shop is right, if you are going to order parts before opening the block they should be oversized.
purevision01 is offline
Old 09-17-2008, 10:53 PM
  #338
SoFloTC's Avatar
eh they shipped my pistons already so i have to send them back i told them to have CP make me 89mm bore pistons and restock the ones they sent me. does the head gasket match the bore of the pistons? would a 89 gasket be good for 89 pistons?
SoFloTC is offline
Old 09-18-2008, 12:10 AM
  #339
coryjames's Avatar
you guys want to see something pretty
coryjames is offline
Old 09-18-2008, 12:15 AM
  #340
B_Real45's Avatar
Are you actually waiting for an answer before posting pics of your block?
B_Real45 is offline
