Official Motor Build End-All Super Thread!!!
Old 07-15-2008, 09:28 PM
  #41
aen
aen's Avatar
me please? =X
aen is offline
Old 07-16-2008, 08:12 PM
  #42
08superwhite's Avatar
my question is why is there so much failure in the rebuilding of the tc engine?
08superwhite is offline
Old 07-16-2008, 08:13 PM
  #43
yellowxhoodie's Avatar
bcuz ppl think they know what theyre doing when in reality they dont. lol
not reffering to anyone on here at all, just putting it out there.
and also, theres so many things that could possibly go wrong, its hard to get everything just right the first time.
yellowxhoodie is offline
Old 07-16-2008, 08:36 PM
  #44
guttedtc0's Avatar
x2
guttedtc0 is offline
Old 07-16-2008, 08:41 PM
  #45
B_Real45's Avatar
Building an engine requires not much skill. Just common sense and the ability to follow directions.
The hard part is the machining and measuring. That should always be left up to professionals.
B_Real45 is offline
Old 07-16-2008, 08:44 PM
  #46
im not saying its rocket science.
but it does require some knowledge and alot of common sense.
all it takes is forgetting one step, or doing on little measurment wrong...
and its all over.
lol
Old 07-16-2008, 09:53 PM
  #47
yamaha16bw's Avatar
For people running overbore pistons. I'd guess your running a .5 overbore (90mm) since they seem to be mass produced that way, what head gasket are you running?
From my understanding its best to run the headgasket .5mm larger then your bore. Cometic makes a 89mm and a 92mm bore head gasket. So if you have a stock bore (88.5mm) then the 89mm head gasket would be perfect. If your running a 89mm bore should you use the 92mm head gasket? Seems alittle too large for me. Or is there another gasket out there I'm missing?
yamaha16bw is offline
Old 07-16-2008, 10:23 PM
  #48
guttedtc0's Avatar
those are the only 2 I know of
Old 07-16-2008, 10:39 PM
  #49
aen
aen's Avatar
hmm...im going to get started with this stuff pretty soon but i was wondering.
what do i have to do? like what do these terms mean? to sleeve a block and what does changing your pistons achieve that would allow you to handle more boost? and would just pistons and rods be good? or more?
aen is offline
Old 07-16-2008, 10:50 PM
  #50
guttedtc0's Avatar
sleeving a block makes it "bulletproof" in a sense.. It will cost you $1000+ easy but your cylinder walls will not flex which will cause engine failure. Essentially you can run more boost
Pistons.. Purchase pistons with a lower compression that stock. This will allow you to squeeze more air into the cylinder without detonating aka run more boost
Rods.. probably the most stressed part of the motor.. you want stronger rods so they do not bend under extreme pressure
I currently have pistons and rods.. head studs and a head gasket. I was planning on running 18-20PSI with methanol on a high boost tune.. daily driving 12PSI. On a T3/T4 60 trim turbo.
But as you can see in my other thread I am having some problems
Old 07-17-2008, 12:25 AM
  #51
aen
aen's Avatar
really. hmm.
sleeving a block = mandatory take out engine time.
pistons = leave engine in?
rods = leave engine in?
how do you get to those without taking the engine out? can you go through the top?
aen is offline
Old 07-17-2008, 01:14 AM
  #52
yamaha16bw's Avatar
I'd take the motor out for all of the above.
Always a good idea to have everything balanced and a hone before new pistons go in.
Old 07-17-2008, 01:20 AM
  #53
aen
aen's Avatar
cuz i figure, take engine out might as well get it sleeved and stuff too.
but i wans't going to sleeve hte engine till later on
aen is offline
Old 07-17-2008, 03:34 AM
  #54
awesome! still learning from this thread.
guttedtc, got a link to your build thread?
now youve got me curious.
Old 07-17-2008, 10:05 AM
  #55
guttedtc0's Avatar
Originally Posted by aen
really. hmm.
rods go onto the pistons and go in through the top
Old 07-17-2008, 10:06 AM
  #56
guttedtc0's Avatar
only thread I have is the one about having trouble with these crazy vibrations
what are you curious about?
Old 07-17-2008, 11:39 AM
  #57
Music City Scions
rhythmnsmoke's Avatar
Getting sleeved later on = taking the motor out and taking it apart twice. Not something (imo) you would want to do.
rhythmnsmoke is offline
Old 07-17-2008, 01:39 PM
  #58
aen
aen's Avatar
yea, i know haha but it would be pistons + rods while engine still in vehicle.
sleeve later on. but i'd do all three all together now
aen is offline
Old 07-17-2008, 02:54 PM
  #59
you said you were having problems as we could see in your other thread, so i thought you had a build thread. nvm.
im just curious about everything in general. always looking to learn more.
Old 07-17-2008, 03:45 PM
  #60
Music City Scions
As per the advice from Ptuning in another thread....at minimum you should get it honed. You have to remove the block from the car and send it off to a shop for honing.
