Official Motor Build End-All Super Thread!!!
Old 09-11-2008, 04:38 PM
  #161
purevision01's Avatar
Originally Posted by SoFloTC
Originally Posted by purevision01
Agreed... Displacement is a personal choice... I prefer higher displacement because it spools the turbo faster... You like small displacement bcuz you can wind the crap out of the motor, which I like too but when I think of the possibility of missing a gear at 8000+ ... I get a not so warm feeling, especially as a builder of customer cars. Thats all I need to hear... Im grindin every shift into 2nd and 3rd cuz your tranny is defective... Nooooo, you grind bcuz you rounded the teeth because you cant shift! lol just a lil personal experience.
hmm so what would ur suggestion be for a person with a built auto tranny? looking to make a street monster pushing about 14-15 psi DD
Really depends on the power you want to achieve and how much you want to spend...
But lets say you want to max out the stock fuel system... 380-400 is about what Id stop at... (400 max hp if you have a really good tune, and I wouldnt run this everyday). 60-1 or gt35 either can be standard journel bearing or ball bearing your pockets decide... I prefer manlely rods bcuz they are rated for 1100 hp and the cost less then the carrillo H beams... CP pistons if its every day driving or JE for minimal driving... JE is made of a softer aluminum so it is able to absorb the stresses of detenotion better then the CP but they get piston slap at start up so over time the cylinder walls will scuff and the car will smoke after a while. I prefer supertech dual valve springs, retainers, and valves bcuz together they are rated for 15k rpm. 750cc injectors with one or two intake walbro 255 low pressure pumps... Port the exhaust runners in the head to gasket match. 2.5" exhaust with cut out or a full 3"... Greddy ultimate with 3 bar map sensor or full standalone from hydra. clevite bearings, arp head studs, and cometic head gasket.
This is the setup we use on just about every tc we build depending on the amount someone wants to spend... I believe there was someone in this forum that used an identical setup and made just under 560 whp on stock sleeves (not recommended) but the only addition to the setup was a larger more capable fuel delivery and return setup.
purevision01 is offline
Old 09-11-2008, 04:41 PM
  #162
Forgot that 560 was on 19 psi and larger injectors but i think their wg was failing and they werent even able to achieve full boost... Not sure how that ended but definitely made good power...
Old 09-11-2008, 05:02 PM
  #163
boosthappy's Avatar
so wat do yall think 8.5.1 or 8.8.1 or 9.1 i want to run a low comp so i could run more boost and timing safely
boosthappy is offline
Old 09-11-2008, 05:37 PM
  #164
9.0 to 1 is fine... Just a lil food for thought... Stock evo makes 315 on 18psi with a good tune depending on the mods... Stock block on honda b18c on the same boost and same size turbo will make 400... Evo has more displacement but lower compression... so to compensate for the drop in compression more boost is needed... Only way I would suggest going that low in compression is if you car was meant to go in a straight line... The lower compression wont matter because when racing you dont have to worry about gear selection... Everytime you shift your car will remain in its nominal rpm range.
This again is just my personal preference on how I build motors... Theres always more then one way to skin a cat, its just a question of how big a cat you wanna skin. lol
Old 09-11-2008, 05:47 PM
  #165
SoFloTC's Avatar
hm
SoFloTC is offline
  #166
SoFloTC's Avatar
so u think on a GOOD tune and meth injection someone could run 12 psi daily driven? on stock internals just bolt on kit .
SoFloTC is offline
Old 09-11-2008, 05:51 PM
  #167
B_Real45's Avatar
With a GOOD tune you shouldn't even need meth injection at 12psi.
The water/meth injection is just for added safetly - it's totally up to you.. if it makes you sleep better at night, do it.
SoFLo, should I invite you to go with my buddy and I when I'm ready to go to Japtrix? I think this will happen in like a month or so.
B_Real45 is offline
Old 09-11-2008, 05:56 PM
  #168
coryjames's Avatar
the motor build has begun
darton sleeves
k-1 rods
je pistons
block is off to the machinist tomorrow or monday
time to max out the 30 r
coryjames is offline
Old 09-11-2008, 06:02 PM
  #169
B_Real45's Avatar
darton sleeves
k-1 rods
je pistons
You're not going to max out the GT3076 unless you get some headwork done...
B_Real45 is offline
Old 09-11-2008, 06:13 PM
  #170
coryjames's Avatar
U think? lol talk to java he knows whats going on lol
Old 09-11-2008, 06:16 PM
  #171
^^ agreed head work, intake mani, and throttle body and about 35 psi lol... and then you can go to the 35r if you like makin baby steps or if you wanna jump to the big dogs get the 40r and put that thing on a trailor.
Old 09-11-2008, 06:22 PM
  #172
B_Real45's Avatar
I rather wait 'till it happens and see for myself..
B_Real45 is offline
Old 09-11-2008, 10:24 PM
  #173
1UP Crew
caveman's Avatar
Originally Posted by B_Real45
This would be my way to go if I wanted a low boost street car, with solid reliability (from tune and built internals).
I forgot to ask this question. Ive read this thread maybe twice over now, lol. I see majority ppl building their motor are running real high boost 15+ for example..
Ive been reading sleeving is really necessary for 350-400hp also. Sooo
What necessities would you say Im missing from a sub 10psi built motor?
Head PnP'd with upgraded VT
K1Rods
Higher Compression pistons (Having a hard time finding these, only finding lower compression, know where i can find them?)
All new ACL bearings
Head and block decked
caveman is offline
Old 09-11-2008, 10:33 PM
  #174
boosthappy's Avatar
ok i see what your saying so 9.1 is a good ratio what about the bore size 88.5mm or 89mm..thanks
  #175
SoFloTC's Avatar
Ya rob that would be great considering im going to have them tune me at 12 psi with meth in about a month .. we can all roll up together!
SoFloTC is offline
Old 09-11-2008, 11:27 PM
  #176
coryjames's Avatar
i had a beautifull package when i got home lol one step closer to the final goal
Old 09-11-2008, 11:54 PM
  #177
1UP Crew
caveman's Avatar
Nice!!^^ congrats
caveman is offline
Old 09-12-2008, 12:42 AM
  #178
java09's Avatar
he has teh planssssss
java09 is offline
Old 09-12-2008, 12:51 AM
  #179
coryjames's Avatar
the plan is in the back of my 92 geo tracker going to ridge reamers to get cut and assembled tomorrow head will be on its way as soon as the "one off" special 2 parts get here lets just say my xb will be slow interior coming out this week hopfully for the jungle gym to be put in
Old 09-12-2008, 02:42 AM
  #180
boosthappy's Avatar
im ganna go with the Je's 9.1 89mm bore dish piston what do yall think
