Official Supercharger Information Thread
#381
This is copied and pasted from a site i found:
Fuel and air goes into the cylinder. This is ignited with a spark plug and goes bang. This bang generates heat which is transferred to several components including the spark plug. Several design factors affect how the spark plug "retains" it's heat. If the plug dissipates the heat from itself quicker than another plug, then it is a colder grade plug. If it dissipates the heat slower, then the plug is a hotter plug.
If you modify your engine e.g. increase boost pressures then the engine will run hotter. Therefore, the standard spark plug will run hotter as it can only dissipate so much heat into the cylinder head. Now consider a hot spark plug and a fuel/air mixture waiting to go bang. Normally, the mixture will ignite in a controlled fashion i.e. when the spark plug sparks, but as the tip of the plug may be too hot the mixture may ignite prematurely; resulting in detonation and maybe a broken engine. If you are lucky then only the plug will melt/disappear! (I've seen it happen).
#382
#384
^ look for someone selling one on scionlife - put a post up if need be. You will find someone somewhere at some point that is selling one. This forum works in a few ways - either someone is selling what you need and you buy it or you wait around for a few months and you will see someone selling one. I had my blower in the garage for 4months and just waited till someone PM'd me saying they needed one asap. Put it in your sig and keep posting - someone will PM you out of the blue one day
#386
i live in MD, i'm trying to get rid mine, selling the car soon..i got auto.
it's 05
TRD reflashed
w/ NST pulley 9.5 psi w/ gate belt 070890.
I got 2 belts..got the stock S/C pulley and belt too.
i'll trade you for ur stock spark plugs, injectors and belt, and air box + 400 on your end.
Let me know. Txt 240 601 2674 or email me @ mkhoid@hotmail.com
it's 05
TRD reflashed
#388
Can a mod please edit this Information thread?
This is completely incorrect statement. I added a Innovate wideband to my supercharger with a hks ssqv fully atmospheric BOV w/ bov adapter kit. At any throttle position the gauge will read 2 lower on the air/fuel ratio when the BOV goes off. This indicates a rich reading when the BOV goes off.
Example:While 3/4 throttle I have a air/fuel ratio of around 12. The blow valve releases air from the charge pipe and the air/fuel ratio goes to around 10 for a split second.
NO FULLY ATMOSPHERIC BLOW OFF VALVES- Will cause a lean setting when you shift, the MAF needs the air to recirculate back through it so it can get a proper reading.
#389
Catch Can Related
On the intake manifold you have a traditional breather hose that comes off the valve cover into the intake manifold. And another into the intake. Cap off the manifold and route your breather line to a catch can or back into the intake "I prefer a catch can to keep the intake assembly clean and keep buildup from happening on your intake valves and ports." Also oil vapor lowers octane which can cause your engine to pull timing and then a loss of power if it senses knock". The best part about fixing these issues is you will gain throttle response and I gained around 1-1.5 psi across the board which means I was most likely leaking a small amount of boost back into the intake.
#391
#393
Anyone who understands forced induction and how a bov works, and how that related to the position of our maf sensor will know that what b52hDUNN says is true. An atmospheric bov on the s/c will make you run which, but it will work fine and is safe.
#394
How do i put a bov on a supercharger?
#395
lol hey sweet kinda glad i read this well some of u know but i totaled out my car last week and i went back up to grab as much as i could, wish i could of took he supercharger due to the fact it has gompkas shaft (no homo) and kik bearings but i was able to grab my bov setup and intake so this stuff will be for sell. pm if you have any questions. might do a supercharger start up kit which will include injen intake, plugs, hoses, bov, and throttle body spacer for 250. idk we will see
#399
#400
does anyone actually enjoy having their SC? I found one for my auto 06, looking for some extra power, but turbo seems like a big headache. Can you really feel a good pull with the SC?
