OH MY GOD!!! ONLY 160 WHP???!
i'll give u all a chance to save a life, because if no one tells me what tha f### is wrong with my car i'm gonna place my head insted one of the pistons...
guys, i drive a camry (i know i know why don't i go to the camry forums...etc)
i've made my own stage zero turbo kit, just like the ZPI's one... 5psi, no intercooler, no emanage or fuel system upgrades...etc only a catless exhaust system...
guys i don't believe this
160.52 whp <<<< OH MY GOD!!!!
WHAT THE F### IS WRONG??????????
160whp/5500rpm and 172 tq
i expected something around 205-220 . . .
there's nothing wrong with the clutch, the A/F ratio is around 13.1 to 12.4 (i know it's a little lean but it woudn't waste me 50WHP!!)
all the turbo pipes are similar in position to the other tc kits
so... what's wrong?
<< holding a gun up his nose with a tear hangin' on his eye
so... what's wrong?
Re: OH MY GOD!!! ONLY 160 WHP???!
the ZPI kit doesn't need any tuning right? why do they get that awsome 220 whp??
i believe the camry carries the same exact 2AZ-FE engine..
They DID and DO make that power, without any management. Upgrading the spark though is pretty much essential. But why would you stay at only just throwing on a turbo and pipes? It wasn't because people ran into problems, it's because they wanted more. There are dyno sheets on here, and personal experience from people that verified their A/F ratios and power numbers.
But with that said, the camry's Ecu I would imagine would be different for that of the tC (could be wrong).
Team No Limitz
i can guess only one thing...your ecu is pulling timing like a ****...get a scan guage or somethin hooked up to that bad boy and see what the timing is @ WOT
Well, I can say from experience that adding air without adding fuel will yield a gain, but yeah, timing adjustment is critical. My old setup had a greddy supercharger on an xB with stock injectors, went from 86 whp to 114, however I was running a 13.6 A/F ratio at the top end, not in my comfort zone. I added a fuel rail and injectors because duty cycle on stock was at 100%, coulnd not physically richen it up on the top end. With tC injectors, A/F dropped to 11.6 across the board, very safe and reliable but HP also dropped to 108. Looks like I need more boost.
Just adding air will lean out your mix and make power, at least until you detonate your engine. eManage is 400 bucks, less if you can find it used. is it a wide-band installed? if those A/F numbers are correct it isn't running lean, good luck and check with an experienced tuner in your area, or make a trip to visit Paul.
It's not a ____ing match just passing along information from people who actually had and reported their Stage 0 experiences.
Originally Posted by kikcaffine
Check make sure you dont have a VAC leak, are you rocking the stock exhaust still? Any idea what your car dynos STOCK?
i don't back pressure would cause this much loss
so you're telling me that an e manage will boost me up to that fine 220whp????
<<< finds it a little hard to believe
