OH MY GOD!!! ONLY 160 WHP???!
#41
Originally Posted by OuterHeaven
Well if your injectors are too small then there will literally be a HP limit they can make. Also the tuning on the ZPI stage 0 was not needed because they placed the MAF in the intake pipe a certain way. I personally had a Stage 0 for over 6 months with no e-manage, no injectors, and no intercooler and it made plenty of power to out run SRT-4's and such. Also I ran another 6 months with only a intercooler added. I now have engine management, injectors and boost control (basically a ZPI stage 1). Also I bet your stock ECU is pulling timing completely and that will KILL your power.
can u tell me please where the MAF sensor should be?
i'v put in the same old place right after the air filter
#43
what kind of dyno was it? mustang dynos read really low. or mabey it just wasnt calibrated right. try taking it to a different one and see what happens. what does the but dyno tell you? does it feel like more than it says you have?
#45
it was a dynojet winpep7 or something like that...
the guys there only tune chevys but they said it doesn't make a difference
well i did the 1/4 mile run in around 15.5sec, stock is 16.8
i feel improvement but not even close to what i expected
#46
Team No Limitz
Im guessing you dont have an EGT gauge right? You might have some really really high EGT's and as I stated before your ECU may also be pulling a significant amount of timing. Do you have any CEL's on the dash? If I were you I would go back to square one, uninstall the major components of the kit and reinstall with new gaskets, use rvt high temp silicone on everything, check all your vacuum lines and reset your ecu by pulling the EFI fuse
#48
interesting point of view...
ok boss i'll try that out
#49
Originally Posted by kikcaffine
Originally Posted by draxcaliber
stock tc injectors are like 370 cc, and then the ones with the supercharger are like what...420 cc?
#53
Team No Limitz
Originally Posted by jakedudeta
U turbo'ed a camry, that's your problem - its kinda like putting a big wing spoiler on a prius. Yee haw!
SloTC1
08-16-2018 03:45 PM
OTOC
Regional - Pacific Northwest
04-25-2015 07:43 PM
