Oil Catch Can
Oil Catch Can
Can someone do a DIY for a catch can install (tc of course)...not sure which lines to tap, or wheres the best place to get the most out of it...there is a DIY but the person that setup the diy has the pictures cancelled... and where is best placement for S/C(i know some people put it in the place for the stock air box....HELP!?!
yeah, i got one off of ebay and installed it with the supercharger. I attached it to the firewall behind the motor just above the intake manifold. Fits well and keeps the hose runs short. I have both crankcase vents running into a T-fitting, then the 3rd port on the T goes into one of the ports on the can. The other port from the can runs to the intake on the supercharger to suck the hot gases out of the engine.
I also needed two adapter fittings to step the 15mm pipes to a 9mm pipe to connect everything up.
I don't have any pics of it, sorry. But it really isn't too hard.
Here is a link to where I got the reducers from ( you can also get the T here)
http://www.brasscatalog.com/catalog_...cd=no&page=225
The reducer part number I got was 33-409W and is located at the bottom center of the page.
Klashan
09-24-2015 01:39 PM
BlingSlade
09-05-2015 09:52 AM
