Oil Catch Can for s/c?
Old 07-26-2007 | 11:47 PM
jwaggz82's Avatar
Default Oil Catch Can for s/c?
Is there any need for a catch can for use with the s/c?
Old 07-27-2007 | 12:06 AM
06SuperWhite_SoCal_tC's Avatar
Yes, very good Idea. I recently got around to installing mine.
Old 07-27-2007 | 12:15 AM
The way it's set-up stock I notice that the boosted air goes through the breather on the intake manifold pressurizes the head and blows oil through the other Pre-throttle body side breather.
Old 07-27-2007 | 12:18 AM
Rather crude drawing, but I think you can see what Im explaining.
The Charged air that is going through the breather into the head, pressurizing the head, also blows by oil into the other exiting breather tube.
Old 07-27-2007 | 12:34 AM
jwaggz82's Avatar
interesting - did you do the homework in which one to get at the best cost?
Old 07-27-2007 | 12:41 AM
Garage1217's Avatar
Also on the pressurizing the bottom end, you do loose a small amount of boost when this happens & the pressure in the case is horrible on the seals / bad overall. Was a nasty oversight by TRD. I noted this last year somtime in the sc post I made.
Old 07-27-2007 | 12:43 AM
jwaggz82's Avatar
^ please explain a bit more - i missed that post
Old 07-27-2007 | 12:49 AM
jetlounge's Avatar
For the S/C, I installed a Dual baffled catch can:
http://blog.scionxtc.com/blogs/archi...catch-can.aspx
For the pressurization issue and reduce blowby I used Krank Vents to increase vacuum:
http://blog.scionxtc.com/blogs/archi...rank-vent.aspx
Old 07-27-2007 | 12:59 AM
I just picked up a cheap one for now, from my buddies car shop 222 Motorsports. But later I want to get a better set-up. It works for now though, with the previous stock set-up I was losing oil like crazy due to blow-by... about a quart every couple weeks. Oil level stays constant now with the catch-can, no loss between changes.
Old 07-27-2007 | 01:04 AM
This is the set-up I'm interested in. Are there pre-existing holes that you attatch the catch-can to under the battery?
Old 07-27-2007 | 01:29 AM
jwaggz82's Avatar
^ read it - it shows you that you use one of the holes from the battery plate
hotwheelsrs1's Avatar
where did u buy those cans and pcv valves, do u have any pn for the pcv's?
Old 07-27-2007 | 01:41 AM
jetlounge's Avatar
the can is from Saikou Michi and the krank vents i ordered from Automotive Speed. Links to both of their shops are in the articles.
Old 07-27-2007 | 01:48 AM
jwaggz82's Avatar
woo baby - its a few bucks for those few things. I was thinking they were around $80 - good deal though .... I might be down for it .... its too bad there is such a minimal amount of room to work
Old 07-27-2007 | 02:12 AM
man, those are pricey, so did u notice a difference on the butt dyno by chance?
Old 07-27-2007 | 05:30 AM
Anybody else with a Catch-Can, what did you guys use to plug the Intake Manifold bung?
steeze69
05-24-2021 03:57 AM
mudguy
10-22-2015 05:31 PM
BlingSlade
09-05-2015 09:52 AM
antayala
09-04-2015 06:12 PM
Quick Reply: Oil Catch Can for s/c?
