oil clearance on rods and main cap..
search please....but to aid.....it depends on what oil you want to run...10w30 youll need to be a tad over spec......i dont have the BGB handy or id give them to you exact....search in this section...elevationtc had the same question and i posted specs in there
im not sure what kinda of hp level im will be running at.. because right now im still going to run the sc. until it blows up then ill go with a turbo kit.. i guess my hp level is around.. 350-430 or so.. the upper #s will be with a turbo set up..
How can you "adjust" the clearance???? If you are installing new bearings and rods....there is no way to really "adjust" the clearance correct? I also had the same question in regards to clearance-thanks
have the line bore checked, if its out of spec for some reson have them hone it. They can also do a line hone and loosen it up to the loose end of spec, whitch will increase your oil crearance as well. But it will also reduce the amount of crush in the bearings.
mischadoll
03-09-2015 05:48 AM
