Oil cooler + filter relocation kit
^^ ask crush! i sold him a very similar kit.. the oil filter should be in same place, just the sandwhich adapter goes in between the filter. i have a pdf of installed pics of a similar oil cooler somewhere, give me your email
Re: Oil cooler + filter relocation kit
Originally Posted by Cwatz5219
what do you guys think about this? im wondering where it relocates the filter since it comes with no instructions.
so it doesnt relocate the filter at all? as per the discription it does to provide easier maintenancing and give it a sportier look
on the outside of the car for better cooling.... preferably infront of the bumper where the air will hit it when your on the highway.....
Jokes aside, mount it whereever you want dude, shouldn't need to ask that question. With that kit your only restriction is the length of the lines.
Oil filter relocation on the TC is ricer mod, please do not do it, not needed.
Oil cooler? Depends on what you do with your car, most do not need it, few of us do.
Anything you add to your car that is does not really need only makes it slower, even if you need it you can still be slower but last longer (road racing and TT with a boosted engine are about the only time you will ever need an oil cooler on our cars;)
Spend your money taking off weight unless you really do need the parts you are interested in, they you are faster and not suckered into the marketing BS that goes on in the "performance" world.
Rick
Rick
Rick
Rick
as ace stated i installed the oil cooler he sold me, but i must warn you that it may increase the oil pressure. Therfore extra care should be given on cold start ups where the oil viscosity is higher and elevated pressure levels are observed.
I installed it primarily because of paranoia but found that it helps when making a few runs down the drag strip.
if you do install it I would suggest having a oil pressure gauge so you can see what kind of pressures you see at different ambiant temps. Knowing how high your pressure is at will help you be able to make a judgment call on when to beat on your ride and when not to.
I have to agree, it can be useful on the drag strip, if you get enough runs to actually start increasing your oil temps. Quite honestly though, unless you are making insane power, still probably just slowing you down.
You can run 290 degree oil temps on a road race course and survive for long durations;) My car runs at 240 or so now which is no worry at all
If you are running your car hard enough to be concerned with oil temps either you are making huge HP on a drag car or you should be on a road race course, certainly not on the street;)
No offense meant at all as this is a general statement, not aimed at anybody in particular, I just want to point out truths since we are surrounded with so much nonsense in what we do.
Note: A better radiator can help deal with oil temps and not add as many more things to go wrong, like oil leaks. I just about ran off the track at 120 MPH not that long ago because of an oil leak that was not there for months, suddenly happened, big bucks hardware failed. If I did not have a need for the cooler thus no added lines, nothing would of happened.
Every mod you do brings more maintenance, costs, negative aspects, I suggest only doing those you really need and spend the rest of your money learning how to drive. and that goes for myself as well
Rick
Rick
