Oil Cooler Kits
Oil Cooler Kits
Is anyone on hear running an oil cooler kit? If so, what set-up are you using? I am looking into getting one and am curious who is using these with success.
Thanks!
Thanks!
Haven't seen any oil cooler kits in the mainstream for the tC yet but putting one together yourself is fairly simple and cheap..
Heres a generic parts list that a 350Z guy used. Should be more then sufficient for length wise and core wise for a turbo tC
As for the Mocal thermostatic oil filter sandwich adaptor I believe the Tc has a 3/4 UNF - 16 oil filter flange on there. If that is the case you can get the Mocal adaptor here http://www.racerpartswholesale.com/mocal.htm
The part number is SP1T. But make sure thats the right thread pitch for the tC.
Originally Posted by 350Z write up
If you're going with a Thermostatic sandwich adapter that has NPT fittings,
then the Holley/Earl's part #s are
1. Setrab Oil Cooler, 25 row, 13.0"x7.5"x2.0", -10 AN fitting,
Setrab part number #50-625-7612.
3. 90 degree bends for a hose Size 10. These are for the Mocal Sandwich adapter.
1/2" NPT: 829010ERL.. you need two of these.
4. -10AN, the swivel hose end that attach to the Setrab cooler are:
-10AN, 90Degree: 809110ERL
-10AN, 120Degree: 812010ERL
5. 6feet of the EARLS prolite nylon hose size 10, i dont have the part number for that...
Some pics of the setup on the Z:
Originally Posted by malibuboy54
hey jarod, how's the turbo treatin' you these days? got all the kinks out yet?
Jarod
Jarod
Heir Automotive also has an oil cooler kit out. I'm getting mine installed as soon as i can get some time off of work.
http://heir-automotive.com/store/pro...roducts_id=158
cessblood
09-15-2015 06:50 AM
my06tc
06-25-2015 12:18 AM
