Oil drain line
Oil drain line
Well iv come down to just needing one more part for my new turbo setup and that is the Oil drain line for the turbocharger. I know i need to get a -10an or 5/8 line but what would you guys say to this?
http://cgi.ebay.com/ebaymotors/TURBO...Q5fAccessories
Reason im considering this is cause im not sure what length of line i would need so im thinking this should work but do ya think this is just junk and looking to blown seals in the future because of the line collapsing or would this be just fine. If this is junk, any suggestions or alternatives would be great.
Note: I have a custom kit i pieced together using a TT mani and a 60-1 turbo incase anyone needed to know for any reason.
that should work, if its a real SS braided.. but return line length depends on your setup..
this is what i bought, i think i have a 19" oil return
http://www.atpturbo.com/mm5/merchant..._Code=ATP-OIL1
PLEASE do not buy that kit.
I bought it and the AN fittings are garbage metal and the line wasnt long enough. I lost my $40
I made a return line setup from this websight, works perfect and is about the same price
http://www.anfittingsdirect.com/
i got two -10an fittings and 3' of -10 stainless braided line from summit...cut to fit FTW!!!!!!!!! though an fittings are a pain sometimes to get on the hose but well worth it imho
Thanks guys for giving some input on this. Spent a little extra than what i would have on ebay but i took NVMyTc input and placed my order thru them. Spent $63 for the fittings, line, weld on pan adapter, and the flange for the turbo's oil drain.
kleecker
04-04-2015 02:37 PM
